Results 1 to 7 of 7
    pinkfloyd5eg's Avatar
    DARK SIDE OF THE MOON
    Question Vag EEPROM Programmer v1.18p3 !
    please if someone had a long experience with this software vag EEPROM programmer v 1.18p3 , as I know it would work with the hex+can interface VCDS from ross-tech, but my question here is : what are the actual VW models that are supported by this software for the following functions : PIN / (security access) code extracting.
    reset for Airbag modules + read /write eeprom.
    mileage adjustment.
    ECU eeprom/flash>> read + write.
    immo box>> read+write.
    tanx in advance!
    << KEEP LEARNING W.O LIMITS >>
    2 Simple Methods To Say Thanks on DK
    Press Thanks _OR_ Add Rep
    Dec 2010
    I am looking for this program too, lost backup. Any link to PM please.
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    https://www.rapidshare.com/files/454...G_Eepromer.rar
    VagEepromer don't have this function "ECU eeprom/flash>> read + write" and
    "reset for Airbag modules + read /write eeprom" is for a few controllers.
    Work on following models:
    - VW Golf 4 - all models,
    - Skoda Octavia I, Fabia (non crypto),
    - VW Passat B5 (VDO Only),
    - Audi A4 (VDO and RB4 non-crypto),
    - Audi A6 (VDO non-crypto),
    - Audi White Immobox.
    Quote Originally Posted by lupu_sandu View Post
    it has the menu of the ECU functions but no active commands there! also plz ,r u sure it doesn't work for octavia II at least mileage or pin code immo3 ??
    Default vag programmer v1.3
    here is another simple version v1.3 works with the serial vag interface, can read ECU + mileage adjustment ,of course for old vag models
  6. The Following User Says Thank You to pinkfloyd5eg For This Useful Post:
    semga (25th May, 2017)
    Quote Originally Posted by pinkfloyd5eg View Post
    can you upload it somwhere else?
    Quote Originally Posted by power1977 View Post
    can't u download ??
