Nabilosat Enigma2 Black Hole - DM7025 v0.5F2
What is new in this version 0.5F2 ?
Enigma2 Version 2.6 experimental
This version of Nabilosat Black Hole is using the experimental version 2.6 of Enigma2. The image is very fast, reliable. Zap speed is even better than ever
NOTE
please read first
You can install this image to flash, without any further support.
You can install this image to multiboot. In this case, you must have an updated image installed to flash. Else, many new features will not work properly.
Nabilosat team reccomends the Nabilosat DM 7025 Pure Flash dated 12 December 2008, available here, or other images released from today onwards. The CVS of the image in flash must be after 10 December 2008.
Enigma2 CVS date
10/12/2008
Updated DVB Drivers
The DVB Drivers are now the latest available version, improving cardreader speed. Many thanks to Linsat Team for the report.
New skin Black Cat by Army
Army released a brand new skin for this new version of Black Hole
Enigma2 Integrated Sky IT EPG
Updated Sky EPG IT, including full titles for 8 days. By MaxZ4
OSD with Channel Number
The OSD Info Bar will now display the channel list number.
OSD with Orbital Position and Satellite Name
The OSD Extra Info Bar will now display the Satellite name and orbital position
Drives and CVS
Updated to the lastest available version
Web Interface
Updated Nabilosat Web Interface.
Web Interface
Button icons fixed. Now you know what to press on your remote control.
NEW NEW NEW: Latest Plugins CVS 10 December 2008 directly tested and integrated in the image
configurationbackup
DVDplayer
DVDburn
mediascanner
webinterface
graphmultiepg
pictureplayer
mediaplayer
antiscrollbar
autotimer
emailclient
epgrefresh
fritzcall
googlemaps
httpproxy
imdb
lastfm
mosaic
ofdb
passwordchanger
permanentclock
rsdownloader
simplerss
startuptostandby
trafficinfo
unwetterinfo
vlcplayer
webcamviewer
werbezapper
zaphistorybrowser
NOTE. Most plugins will be available in MENU>PLUGINS or Nabilo Green Panel. Other plugins will be available in the Extesions Menu ( long press blue button )
NOTE. Permanent Clock is disabled by default. To enable it, go to Green Panel > Permanent Clock.
Main Function Keys
Button 1xOK = Light Info Skin
Button 2xOK = Extra Info Skin
Button Blue = Nabilo Blue Panel
Button Blue-Long-Push = Extensions
Button Green = Nabilo Green Panel
Button Green-Long-Push = Subservices
Button Red = Start Record
Button Yellow = Time Shift
Addons
Dedicated Addons Server
Download and install additional packages from Nabilosat server
Infobar/OSD
Enigma2 Analogic Clock
Channel Orbital Position
Advanced Tuner Info: Sr Freq Pol Fec
Signal SNR, BER
Infobar Picons
LCD/OLED Picons
Advanced EMU information
Nabilo Panels features
1) Blue Panel
Setup
OSD Settings
Nabilosat E2 EPG Settings
LCD Settings
Fast Plugin Settings
Inadyn Settings
Swap File Settings
Hard Disk Setup
Nabilo Mount Wizard
OpenVPN Panel
Samba/Cifs Panel
NFS Server Panel
Telnet Panel
FTP Panel
Info
CCcam Info
Memory Info
Available Space
Processes
Service Info
Enigma2 Settings
About
Save
Select/Start/Restart EMU
2) Green Panel
Shoutbox
Fast Plugin
Addons
Addons Download Manager
Manual Install Nab packages
Manual Install IPK packages
Addons Uninstall Panel
Nabilosat Statistics
Scripts
Many thanks to the Beta Testers Team
Black33, ^^Corrado^^, Maximo II, greg, Matrix10, Porto, Nabilo, Army, Piefav, Franzjuve, Willow, fbrassin, Neri73, paribas, astemio, lorenzo64, frimmino, robyhummy, DeepDiver
Credits
E2 Sky Epg loader integration by MaxZ4.
Army for the new Black Cat skin.
Many Thanks to lukkino (VDR-Italia) for opentv source code.
This Images doesn't contain any keys nor softcams.
Backups or other modified Images are not supported!
Nabilosat DM7025 Pure Flash 12DEC08, with Barry Allen 4.6.40
What is the Nabilosat DM7025 Pure Flash ?
This image is a simple, pure CVS image to install to flash memory. It is reccomended to those who like the multiboot option with Barry Allen. It is light, fast, reliable and, most of all, upated. Therefore, it is the best solution for multiboot purposes.
What is included in this image ?
This image is including the latest available edition of Barry Allen: 4.6.40
Why should I install this image in flash ?
Because it includes all the latest drivers and kernel modules required to install new images in multiboot. Nabilosat team is about to release version 0.5 of its Black Hole image. If installed to multiboot, the new Black Hole v0.5 requires an updated image in the flash memory. For this reason, Nabilosat team prepared this Pure version for you.
How do I install Barry Allen with this image ?
Barry Allen will be automatically installed at the end of the default wizard
Will I loose the images alread installed on my media ?
No, you will not loose any of your favourite images, already installed to your media. You will reboot and find them again, ready to be used.
How do I install it to flash ?
You can install it via WebInterface or via serial. However, it is important that you read the simple instructions reported here under.
Release Details
Updated DVB Drivers
The DVB Drivers are now the latest available version, improving cardreader speed. Many thanks to Linsat Team for report.
Nabilosat Bootlogo by MaximoII
Barry Allen 4.6.40 included
TARGET_ARCH = "mipsel"
TARGET_OS = "linux"
MACHINE = "dm7025"
DISTRO = "opendreambox"
DISTRO_VERSION = "1.5.0"
TARGET_FPU = "soft"
COMPILED DATE = "12 december 2008"
ENIGMA2_CVS_DATE = "12 december 2008"
ENIGMA2_VERSION = "2.6 experimental"
BARRY_ALLEN_VERSION = "4.6.40"
Instructions
1) Flash your DM 7025 with Web Interface or DreamUp and serial cable
2) Complete the Default Wizard to setup the basic steps
3) Upon Wizard completion, you will be prompted to press OK to install Barry Allen
4) Press OK once, and wait for the Wizard to install Barry Allen
5) When Barry Allen is updated, the Default Wizard will be completed.
6) Reboot your Dreambox
Barry Allen will have been updated. You will find your previous images listed, choose your favorite as always.
GOTO DOWNLOADS
