Results 1 to 15 of 16
    DK Veteran VTS_Tibi's Avatar
    Default Blaupunkt CD 30 MP3 - no sound (Opel Astra)
    Hi Guys,
    I have a Blaupunkt CD 30 MP3 here from an Opel Astra H.
    The head unit was working OK in the car, then the car was disassembled completely (to have a few panels repainted).
    The car then was rebuilt back, and now the radio has no sound.
    It seems like it's working as it should, shows the CD tracks or the FM frequency, even shows the radio stations name, but no sound at all from the speakers.
    What could be the reason for this?
    Is there a way I can solve this?
    Thanks,
    Tibi
    stefaudio's Avatar
    BULGARIA
    if speaker wire is akcidentli shorted to ground the amplifier cut off the sound to all speakers
    put the multimeter probe to ground and wit other probe mesuer the 8 wires for speakers for short to gnd.
    and another test...solder to 1.5 volt bateri wires ant apli this wires to radio conector and listen if spikers make ticking sound
    sori for bad english
    Jun 2009
    porto portugal
    Quote Originally Posted by VTS_Tibi View Post
    Hi Guys,
    Thanks,
    Tibi
    did you decode the radio ??? if so, the problem is in eeprom.
    good luck
    dashradio's Avatar
    Inafield
    Quote Originally Posted by jjrp255630 View Post
    good luck
    These radio's don't need a code, he said that he only had panel repairs.
    Don't it have a mute button on the steering wheel ? or does it have a phone kit fitted ? if so this could be muting the radio.
    I can't recall if there's a mute button on the steering or not.
    But surely, if I adjust the volume to maximum the mute should switch off automatically, right? Or at least it should write mute on the screen, but nothing like that!
    And as I said before, the radio was working OK before the car was stripped down.
    I asked the owner and he said something which may lead to the problem.
    When the car was put together he accidentally put the instrument cluster's plug the other way round, bending around 5-6 pins in the connector. The car did not start and every ECU had all sorts of CAN errors.
    Then the fault was found, the connectors were put back correctly, the car started, everything working OK, expect the radio.
    when they make the paint work the radio was i his place ,or remouve? maybe water enter the radio
    check if there is output on the speaker wire 6v
    take out the speaker plug and test separate speaker
    did the car have sound ampli?
    no, the radio was removed from the car during the painting
    Fradebo's Avatar
    belgium
    Smile
    THERE IS A SMALL SMD-FUSE SOLDERED TOP-SIDE
    PRESS THANKS IF USEFUL
    GRTZ FRADEBO
    could you please point on the picture which one is that fuse?
    Fradebo's Avatar
    belgium
    Smile
    at your service ......
  12. The Following User Says Thank You to Fradebo For This Useful Post:
    Anon222222222 (28th October, 2020)
  13. #12
    Ireland
    Have you tried to check for audio on the bench. power up the radio using 12v and ground. connect to a speaker . If you have audio then the problem is in the car. Check for short circuit on centre speaker. I have come across this once before
  14. #13
    Quote Originally Posted by Fradebo View Post
    thanks Mate! I suspected that one as it has F3 written on it, but it is OK!
    will test the radio on a bench tomorrow and report
  15. #14
    I've tried the stereo on a bench over the weekend.
    I connected +12V; GND and a speaker, and I got sizzle from the speaker, and it the volume knob adjusted the volume of it, so I guess the radio is OK then!
    I've tried to put a CD into the player, but it did not play the disc - I'm assuming this is due to the lack of display and CAN communication.
  16. #15
    Fradebo's Avatar
    belgium
    Smile
    YOU HAVE A DEFECTIVE CD-MECHANISM.
    IF CD IS TAKEN IN THEN LASER COULD BE DEFECTIVE.
    CHECK ALSO CORRECT POSITION OF LEVERS.
    THE CD HAS TO WORK WITH THE DISPLAY DISCONNECTED.
    I DID THE TEST MYSELF.
    REGARDS FRADEBO
