Hi, got a micra here,1.0 petrol 2004
Fuse for Engine management was blown, replaced fuse and now getting this code, car wont crank/start
P1611 ID Discord Immu-ECM
any idea how to reset?
"I always tell the truth. Even when I lie"
"We Taking Over, One City At A Time"
The fault happens when you try and start a Nissan with a low battery or in your case blown fuse.
1. Ensure battery is charged
2. Erase all faults in the ECM and NATS (if any)
3. Initialize communication between ECU and NATS.
Start car job done. On a rare occasion you may need to reprogram keys.
Hi Z786
I have seen this fault code before on Nissan But, never seen any which will NOT crank, always they crank but it will not fire...
Any way in this case have you checked the wirings from ignition switch to engine bay fuse box, starter relay, and to starter if all is OK...........Also have you tried to power up the starter direct and see if the starter is OK.
Thanks Ash
Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
Hi, car was starting perfect until it had a slight hit, headlight was changed, after that they wer trying to start but no luck, this is a K12 so i think it wouldnt crank???
@xram how do i initialise comm with nats and ecm
Cant remember but I know X431 will do it ill have a look on Monday if I can get my hands on a nissan.
K12!!!!!!!!!! than I agree that it will not crank
in that case have a good look in engine bay fuse box..
Also see if you can get another fuse box to try as they are plug and play..........
Thanks Ash
Put a new battery on, Car started
thanks guys
got another one today, same error code, but this time steering lock was taken out to replace power steering pump. now the immo light stays on solid, sometimes the key light flashes green then goes off, no crank
tried a new battery but still no go, any ideas?
Hang on, flashes green, that would suggest it's one of them funky hands free modules things (like renos) - and in that case it's electric power steering.
Suggest some plank has not quite got a plug in place, or has the radio active lump of smeg off this thraed http://www.digital-kaos.co.uk/forums...-warns-226734/ in their pocket
(got one of them colums in my shed)
Besides, i'm really pished off now, chances are yours is some non paying family job - this is a real proper job http://www.digital-kaos.co.uk/forums...8/#post1246990
Can't find the thread i leeched an Immo off file from to report it worked, oh bolloxks, i'm off to be bye.
Try resetting by removing the fuse marked IK in interior fuse box then clear fault codes and see if that helps............
Thanks Ash
IK wat amp fuse will it be, wat does IK stand for?
Can't remember what amp it is but you will see........... IK is the potion of the fuse just look on fuse box you should be able to locate it...........
Thanks Ash
tried everything, still no joy, light stays on solid![]()
put old EPS motor and car started
maybe needs an internal eeprom swap?
