Results 1 to 8 of 8
    Default TOYOTA AVENSIS VDO ODOMETER CORRECTION 93S56
    Good Evening all.
    Would anyone be kind enough to give me some info on how easy it is to adjust the mileage on a VDO Avensis speedo for 1998-2003 models?
    The chip is a 93S56 eeprom.
    Once you have read the eeprom? is the mileage encrypted or difficult to work out where it is stored?
    Many Thanks
    smartymarti's Avatar
    Jan 2011
    cornwall
    Read and post the dump
    All about the Bass
    Please find attached the eeprom dump
    Current mileage for this dump is 253483 miles
    Preferred mileage is 235780 miles
    Many thanks to everyone
    z786's Avatar
    10 Steps Ahead of You
    here you go mate
    "I always tell the truth. Even when I lie"
    "We Taking Over, One City At A Time"
    Z786 Thank you very much for all your help, worked spot on
    Would the change be the same for 200-2006 Avensis?
    Raz
    z786's Avatar
    different, trust me mate, alot more to this game than it seems
    Dont doubt you for a second, nothing is straightforward nowadays.
    If sticking with mostly Avensis seeing as though its what i get mostly asked for by customers, what would you invest in to do from 1998-2008 ?
    darrenhyland's Avatar
    Aug 2010
    IRELAND
    Tachosoft software and upa usb...........should do the trick!! Oh and a good soldering iron and a hot air station......always remove eeprom and read dump three times to make sure the data is consistent...read in 8 and 16 bit and save in both formats just in case it goes tits up........hope this enlightens you!!
