Results 1 to 15 of 20
    May 2011
    Exclamation Help needed to clear Sly it card
    Please help me pin point the problem and resolve it.
    I received my new Sly it card. it is caid 093b. Activated by the seller before it was sent to me.
    Inserted in lower internal cam (01) of DM8000.
    Image is Dream elite v.1
    Installed Oscam (latest SVN) + CCcam 2.1.4
    sent all the config files to etc/tuxbox/config and chmod 644.
    I don't have my box Id but I understand it is not needed with the later Oscam bin files.
    The card will not clear. The best result I got was clearing few channels, MTV, MTV music, Super tennis, LA7 and Arturo. but these channels are also clear if I insert my old expired card!
    This partial "clear" I got also by using only Scam 3.6 or CCcam 2.2.1.
    Here are my config files..
    oscam.conf
    [global]
    Nice = -10
    WaitForCards = 1
    PreferLocalCards = 1
    saveinithistory = 1
    [monitor]
    port = 988
    monlevel = 4
    nocrypt = 127.0.0.1
    [webif]
    httpport       = 10001
    httprefresh    = 5
    httpallowed    = 127.0.0.1,192.168.0.0-192.168.255.255
    [dvbapi]
    enabled        =1
    boxtype        = dreambox
    user           = localuser
    au             = 1
    oscam.server
    reader]
    label           = myreadername
    enable          = 1
    protocol        = internal
    device          = /dev/sci0
    detect          = cd
    caid            = 093b
    ident           = 093b:0000
    group           = 1
    emmcache        = 1,3,2
    oscam.user
    [account]
    user            = localuser
    group           = 1
    au              = myreadername
    cccam.cfg
    PHP Code:
    SERIAL READER : /dev/usb/tts/0 smartreader+
    N192.168.1.106 10001 user pass 01 02 03 04 05 06 07 08 09 10 11 12 13 14
    Any help is appreciated.
    Nov 2008
    box key might help mate.
    Nov 2008
    Quote Originally Posted by alom5 View Post
    you dont need box key m8 m8 if you are using oscam to read the card only .
    bubbles69's Avatar
    Somehwere in the South East
    yes oscam reads boxkey itself from card no need to add it..
    May 2011
    Thanks for confirming that Oscam does not require a box id.
    I still can't see why it does not clear all the channels.
    Could it be that the card is not auto updating in Oscam?
    And why are these channels also clear on the old expired card as well?
    BTW which version of Oscam does not require a box id line?
    Sep 2008
    i think the card is autoupdating mate im not sure why the old channels clear on old card tho thats a mystery
    Apr 2009
    for oscam to work with cccam
    oscam/cccam must be installed as one package
    not separate
    as for you configs
    you left newcamd protocol out
    cccam and oscam not talking
    means N-LINE doing nothing
    your card is being read by cccam
    cccam needs boxkey for premium channels
    thats why just few basic channels are opening
    when card is read by oscam no boxkey needed
    then premium channels will clear
    also you [dvbapi] is wrong and not needed for separate cccam
    but
    if your [dvbapi] text was correct in 1st place
    oscam
    would of read the card via [dvbapi] and cleared premium channels
    you put
    [dvbapi]
    enabled =1
    should be
    [dvbapi]
    enabled = 1
    to use oscam with cccam
    Add the text below to the right files and it will work
    restart start oscam after edit
    text in red BELOW is NOT needed
    why have you put you have a usb reader in cccam cfg ??
    cccam cfg
    N: 127.0.0.1 12000 test1 test2 01 02 03 04 05 06 07 08 09 10 11 12 13 14
    oscam.conf
    # protocols
    [newcamd]
    key = 0102030405060708091011121314
    port = 12000@093b:000000;12001@093b:000000
    oscam user
    [account]
    user = test1
    pwd = test2
    monlevel = 0
    uniq = 0
    group = 1,2
    au = 1
    caid = 093b
    on remote blue button select
    oscam/cccam
    then ok button oscam will then restart
    May 2011
    Davvo,
    Thank you for your detailed post.
    Since i don't need to share, I tried Oscam on its own.
    I corrected the syntax error in Oscam.config (BTW that error is in many cut & paste tutorial over the net).
    I also updated to Oscam_svn_5225
    restarted oscam on its own..black screen. not even the few clear channels.
    then tried Oscam+Cccam..
    put in your guide/modifications..still black screen.
    Apr 2009
    log in to webif via your browser
    DM IP
    192.168.x.xx:10001
    and post what it says on the log screen
    is the the DM8000 lower card slot
    /dev/sci0
    or
    /dev/sci1
    try in oscam conf
    [global]
    nice = -1
    also edit the b in caid in caps
    caid = 093B
    not 093b
    also try caid 09CD edit all configs
    my guess is you have new card with caid 09CD
    May 2011
    Thanks for your help,
    The lower reader is 0
    Here are my files, please see if there are any errors..
    oscam.conf
    [global]
    Nice = -1
    WaitForCards = 1
    saveinithistory = 1
    [newcamd]
    #key = 0102030405060708091011121314
    #port = 12000@093B:000000;12001@093B:000000
    [monitor]
    port = 988
    monlevel = 4
    nocrypt = 127.0.0.1
    [webif]
    httpport = 10001
    httprefresh = 5
    [dvbapi]
    enabled = 1
    boxtype = dreambox
    user = localuser
    au = 1
    oscam.server
    [reader]
    enable = 1
    protocol = internal
    device = /dev/sci0
    detect = cd
    caid = 093B
    ident = 093B:000000
    group = 1
    emmcache = 1,3,2
    oscam.user
    [account]
    user = localuser
    group = 1
    au = myreadername
    oscam svn5225 used on its own. No cccam.
    I tried bothe 093B and 09CD.
    still black screen.
    here is the webif printout
    Apr 2009
    try these as they are dont edit anything
    just copy paste and restart oscam
    oscam.server
    [reader]
    enable                        = 1
    protocol                      = internal
    device                        = /dev/sci0
    services                      =
    caid                          = 093B
    boxid                         =
    detect                        = cd
    mhz                           = 357
    ident                         =
    group                         = 1
    emmcache                      = 1,3,2
    ecmcache                      = 1
    blockemm-unknown              = 1
    blockemm-g                    = 1
    lb_weight                     = 100
    oscam.user
    [account]
    user                          = localuser
    pwd                           =
    disabled                      = 0
    expdate                       =
    group                         = 1,2
    hostname                      =
    uniq                          = 0
    sleep                         = 0
    monlevel                      = 0
    au                            = 1
    caid                          = 093B,09CD
    betatunnel                    =
    cccmaxhops                    = 0
    keepalive                     = 0
    numusers                      = 0
    penalty                       = 0
    May 2011
    Still not clear.
    BTW my card s/n starts with 00002 so it is a 093b. the 09CD cards start with a 00003.
  13. #13
    Apr 2009
    try these in oscam.server
    cardmhz = 500
    mhz = 500
    cardmhz = 500
    mhz = 357
    cardmhz = 357
    mhz = 357
    cardmhz = 367
    mhz = 367
  14. #14
    May 2011
    Quote Originally Posted by davvo View Post
    cardmhz = 500
    mhz = 500
    cardmhz = 500
    mhz = 357
    cardmhz = 357
    mhz = 357
    cardmhz = 367
    mhz = 367
    I am sure you mean one combo at a time..
  15. #15
    Apr 2009
    like this each time
    cardmhz = 367
    mhz = 367
