Hi!
I have a problem with my clone OPCOM firmware 1.39 and using 081016 software version, when I'am trying to diagnose ASTRA H 2004 OP-COM doesn't see HSCAN?
ANY solution please?
Hi!
Many many clones out there, some better than others, it maybe just a shite clone !
OPCOM works fine in other cars that use KWP protocol (ASTRA G VECTRA B).I just tested this OPCOM with two cars ASTRA H and VECTRA C and the result was same no communication at all.Interface has green plate with 8 relays not 5 with yellow board. It is obvius that communication on pins 6 & 14 has a problem.BTW the opcom is brand new!
Does anyone have schematic for OPCOM with 8 relays.
Maybe this is what you looking for .
1. have a look to the both MPC2551
2. have a look to the relay responsible for CAN
spor
sorry MCP25511 - http://www.digital-kaos.co.uk/forums...schriftung.jpg
atb
hello, I solved same issue on my opcom and it was from the MCP, there are 2 of them near the 16 pin socket
I have the same problem with my opcom not working on cars with Kline Corsa-C-2003,
in the CAN opel. if it works
to work and communicate with Kline cars, which I do,? MCP25511 replace, for which another? and what is the relex for this line?
I would like to repair the OPCOM.
Thank you.
mcp25511 is high speed can tranceivers
depends on your board type
