Results 1 to 15 of 15
    Default SMART 451 2007 SAM Flash
    Hi!
    I need help with Flash of MCU 9S12DG128.
    SMART ForTwo 451 2007 SAM module.
    Thanks in advance.
    DK Veteran wsc's Avatar
    GR
    Quote Originally Posted by Room View Post
    Hi!
    Thanks in advance.
    Why do you want read the FLASH mate?
    I mean there is some reason ?
    Smart car engineer ,
    My friend tried to change the mileage.
    He used XProgM made in China.
    I do not know why he began to read flash, but the resulting unit is not working properly.
    I tried to reprogram the unit with the DAS 03.2011, nothing has changed
    GR
    Mate caution
    Read and write ONLY the EEPROM
    if you want to make any changes
    You can use the xprog-m even and clone
    Thanks for the reply, but
    I still need full flash of SAM, because SDFlash in DAS has incomplete data.
    I think my is corrupt.
    GR
    Mate you misunderstand me.......
    We dont talk about DAS and how many year s are u or me working with but for FLASH programming with Programmer like Xprog-m(it is not official programming) let me know better from you mate, i have "burn" many many of this SAMs
    I am working 10 years ONLY with SMART cars
    anyway if u want keep my advice or make it with your way
    Good Luck
    I understand you ..
    I do not change mileage, I restore the cars after the mistakes of others.
    I have to use different equipment or buy new units.
    Unfortunately, there is no such unit in my database.
    That's why I asked for help.
    Good Luck .
    GR
    I understand you ..
    Good Luck .
    ok then there is two options before u buy a new SAM
    1)desolder the MPU from the Board the MPU is 9S12B128 mask 3L80R and use BDM programming,ERASE EEPROM and FLASH once and after that i will sent you dumps for programming,in this case u will need and two NEW keys for initial start up with star diagnosis
    2)Buy a used one and make a clone pm me for more details with this procedure
    Gd Luck again mate
    Quote Originally Posted by wsc View Post
    Here is flash from my MCU.
    EEPROM is seems to be correct.
    All keys ( ID, Hi, Low, key count ) are right.
    All CRC also correct, so I not need to change keys.
    I can write keys in used one.
    Check my Flash file, if you have correct, please.
    Land of Rocks
    maybe the eeprom its not corrupted. perform a full flash and eeprom reading and post the dumps. maybe you need only flash and recover your MCU. this happenes.
    GR
    EEPROM is correct. All keys ( ID, Hi, Low, key count ) are right.
    mate your Flash file is correct
    did you tried to write it again?
    Thank you very much
    Another question.
    Unit came to me without the MCU.
    I have not 9S12B128(3L80R) right now, only 9S12DG128(4L40K) / 9S12DB128(0L94R)
    Is 9S12DG128(3L40K) installed in earlier versions of SAM?
    I have successfully changed 9S12B128(3L80R) with 9S12DG128 (4L40K) is SMART ForFour ETACS unit.
  13. #13
    GR
    Sorry mate i have never seen 3L40K in the SAM 451 unit not even the first of them,i mean 2007 year but maybe is the same i do not know if will work
  14. #14
    GR
    If this help you i have upload Original eeprom
  15. #15
    mitext's Avatar
    Feb 2011
    i need this damp please PASS...
