Results 1 to 14 of 14
    Turkish
    Default inmo Rover 25 eeprom 24C04
    Can someone help me cancel inmo a Rover 25 with eeprom 24C04 ECU Bosch 0281001956
    Turkish
    Anyone know the procedure for this car?
    DK Veteran chiptorque's Avatar
    Nov 2010
    this is like the opel ... I advise you to cut the pin 35. to me it has worked ... but the file is not correct ... try this ...
  4. The Following 5 Users Say Thank You to chiptorque For This Useful Post:
    abrara (8th February, 2017), kazikk (3rd August, 2016), mcday (23rd December, 2014), remigijus56 (30th March, 2016), ruicosta (8th December, 2015)
    Meat-Head's Avatar
    did this work
    Good question.This thread was in year 2011 all thanks was post after 5 years and nobody share if the solution is good or not.
    So please share if work and must cut pin 35 or 37.
    Jan 2017
    24c04 no_immo.zip
    With this file car works 100% - checked in my workshop
    But you have to:
    1) cut immo line pin 37 (blue/gray) of engine ecu
    2) give additional ground on relay called "SM" in engine fusebox (starter motor relay)
    3) remove alarm module (behind radio) and desolder buzer from inside
    4) cut 4th pin from the smallest plug (3rd one) blue/pink - this is red immo diode on dash
    5) if engine check light is on cut also pin 42 of engine ecu (YELLOW/RED OR GREEN/RED)
    Works fine
  8. The Following 16 Users Say Thank You to pwrider For This Useful Post:
    Adrigaaas90 (7th October, 2023), andrej2003 (30th November, 2017), davidtrus (29th July, 2022), dieguisimo (21st October, 2022), flaviu_syzu (29th January, 2019), Gatchet00 (24th November, 2021), hrmotorsport (22nd March, 2022), Jabeer445 (5th April, 2024), javiere (11th December, 2020), lirinikut (6th August, 2018), maksstep (24th July, 2021), MARIKO (30th June, 2018), Meat-Head (10th November, 2017), mikajna (28th October, 2023), pawelelectro (25th August, 2020), yurgen030 (9th July, 2023)
  9. #7
    Jun 2016
    tested and running 100% , but how to turn off the alarm.
    Rover 25 2.0 td, 2004, Bosch ECU 0281001956
  10. The Following User Says Thank You to andrej2003 For This Useful Post:
    Meat-Head (1st December, 2017)
  11. #8
    Meat-Head's Avatar
    Try starting and stopping 50 times as lupu says cuts back in
  12. The Following 2 Users Say Thank You to Meat-Head For This Useful Post:
    andrej2003 (12th December, 2017), looly (10th December, 2017)
  13. #9
    Jun 2018
    Guys I want to thank you. The file works fine. I cut the line of the immo directly from the immo box , also cut the starter relay cable. Additional ground to the relay and the starter also work fine. WIth this config you still can use the central locking function. Thanks again
  14. #10
    qwertyuiop12's Avatar
    May 2013
    Hi all,Rover 45 2004,I made immo off files 24c04 no_immo ,car start,but how to turn off the alarm ?
    Alarm modul 4 connectors,
    I tried to completely turn off the unit, but the central locking does not work,
    the interior light, everything that is responsible for comfort not work.
  15. #11
    Dec 2018
    I have a problem with a similar ecu. I will try to see if it works. Thank you
    Quote Originally Posted by pwrider View Post
    24c04 no_immo.zip
    But you have to:
    Works fine
  16. #12
    Sep 2023
    24c04 no_immo.zip
    Works fine
    Sorry about my ignorance. How can I do that? Thanks
  17. #13
    Sep 2023
    Quote Originally Posted by Adrigaaas90 View Post
    Nobody can help? Please, I need some help with the relay cable.
  18. #14
    Meat-Head's Avatar
    Welcome to dk the worlds best website.
    from memory i *THINK* locate the immboliser module that in cente console
    THINK black/orange. When you hold the key to crank become positive. Going through a starter relay
    Somewhere in the middle of the plug.
    find that wire hold key over flash a negative see if it cranks. ‘Next to’ it is black wire join them t’gether.
