Results 1 to 10 of 10
    Usa
    Default help about a Porsche cayenne kessy
    I have a Porsche cayenne My 2006
    with kessy CAN
    just deconnect it
    desolder 93C56 to read dump
    but after solder 93C56 into mainboard
    not ignition or light on dashboard no immobilizer active
    when i diagnose kessy with PIWIS
    i have these menus
    identification
    faults codes
    erase fault code
    adaptation
    replace ecu
    but didn't have measured values,coding!!!
    when i go to identification of ecu i didn't have
    VIN number
    Foxdata a dk members have to read the file with ICC and give me pincode
    now i want to know how to make my kessy work normally
    somebody tell me to change pin directory have to do it but no change!!
    If someone can help me to tell how to check if my kessy have to be broken or want can i do?
    can i swap it with used kessy but didn't have kessy CAN
    i have carprog with kessy tool, AVDI and PIWIS
    regards
    Usa
    Default is it possible to swap kessy
    there are pictures of my matter
    anyone can help me?
    is it possible to swap CAN kessy with an used one but didn't CAN
    regards
    Apr 2011
    in lebanon
    HI DEAR, 1) IT THING BE YOUR EEPROM 93C86 NOT 93C56,
    2) PLEASE SEND TO ME TO CHECK YOUR DUMP IF HE GET ANY PROBLAM ,AFTER I CAN HELP YOU ...
    Usa
    hi
    this is file mate
    regards
    Apr 2011
    in lebanon
    HELLO,1) YOUR PIN IS (03321) PLZ CLEAN VERY GOOD YOUR EEPROM LEGS CARFULLY, AFTER CLEAN YOUR KESSY BOURD. AFTER I DONT KNOW WATH YOU ARE USEING TO SOLDER THE EEPROM .PLZ USE (PASTE FLUX) TO BE SURE IS SOLDERED WELL YOUR EEPROM ON THE KESSY BOURD.
    2) AFTER YOU CONNECT THE KASSY ON THE CAR .PLZ OPN FUSE BOX LEFT SIDE OF DASH PANEL AND CONNECT JUMPER WIRES FROM 26>36>41 FUSES TOGEDER. AFTER CONNECT YOUR SCAN TOOL (I AM HAPPY TO LESEN YOU HAVE AVDI) SO THIS IS VERRY GOOD TO HELP US: PUSH THE BRACK SWICH WITH YOUR FOOD. AND ENTER TO SPECIAL FUNCTIONS & CLIC ON KEY LEARNING.AFTER ENTER YOUR PIN CODE (03321) & NEW KEY COUNT AFTER CLIC LEARN ....
    OK DAER PLZ TRY AND TELLME IF ANY NEW.
    GOOD LUCK....
    Apr 2011
    in lebanon
    DEAR IN THE PHOTO IS YOUR DUMP REZALT PIN CODE & IT MEAN YOUR DUMP IS GOOD + IMMO KESSY + VIN NUMBERS.SO PLZ SOLDER THE EPROM WELL ,AFTER PLZ DO HOW I WRITE TO YOU & I WISH TO BE SLOVE YOUR PROBLAM ....
    Apr 2011
    in lebanon
    DEAR PLZ TRY WITH THIS DUMP.
  8. The Following User Says Thank You to haroutioun For This Useful Post:
    pekelan (20th March, 2021)
    It is really nice that You give answers but dont use CAPS LOCK.
  10. #9
    Usa
    Default new kessy same matter
    now i order new kessy from dealer
    read new kessy code
    but when i try to teach kessy
    after insert key and enter code
    the kessy didn't want to coding
    or to learn
    left connect longtime nothing
    and nothing show on the instrument
    after that i disconnect my kessy
    and begin new teaching but i do a mistake
    i put MY2008 but my carf is MY2006
    now the soft tell me that i precode
    kessy to be use to model MY2008 or after
    and my immo challenge is IV
    how can i do reset kessy
    and make it come like delyvery status
    regards
  11. #10
    dd1's Avatar
    Aug 2014
    Quote Originally Posted by haroutioun View Post
    Hi, can you clear your message box, I am trying to PM you but DK won’t let me because the message box is full
