Results 1 to 13 of 13
    DK Veteran snecii's Avatar
    Default Renault Dialogys on-line
    How can I search by VIn number in dialogys?
    I used to be a dealer, so I can use it but now i don't have renault net.
    Is there any solution to do it like in renault service?
    Or is there any web page for that?
    Thanks!
    Somebody something?
    Nobody? nothing?
    Please
    Can i use other renaul BVM code?
    mybe?
    Liteace's Avatar
    Mar 2009
    On a rock
    How did you log in when you used to be a dealer, cant you just do the same now ???????
    Ashraf6119's Avatar
    UK
    Quote Originally Posted by snecii View Post
    Thanks!
    If you were Dealer for Renault than I am sure you must be knowing better than us about Renaults.
    Then how come you are struggling like other here.......
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
    drakov's Avatar
    Aug 2008
    One word comes to mind........lets have a guessing game
    1st letter .... The english seem to love drinking this
    Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
    Liteace's Avatar
    Mar 2009
    On a rock
    Quote Originally Posted by drakov View Post
    Is it Vodka & Red bull
    Ashraf6119's Avatar
    UK
    Hello
    They you go mate
    Thanks Ash
    At about 2008 Renault.net, closed as a privet line from that point renault.net was a free line and you could use it with a memory stick. BUT for Dialogys you just need your dealer number and a code for BVM nothing else. in one dealer every PC uses the same code.
    SO nobody tryed it before....
    Liteace's Avatar
    Mar 2009
    On a rock
    Why don't you ask in the Ren dealer where you used to work, you must have a mate still there that can give you the codes
    Quote Originally Posted by Liteace View Post
    My own company was a dealer!
    Now we work as a service but not as a dealer....
  13. #13
    Aug 2011
    hola, soy Francisco.
    tengo instalado dialogys, y en vez de buscar con todo el n? de chasis. busco por el tipo de vehiculo y no tengo nigun problema.
    el tipo de vehiculo son las letras y numeros 4,5,6,7 del n? de chasis empezando por la izquierda
