Results 1 to 15 of 17
    Oct 2010
    Default DREAMBOX EDIT....DATEI NICHT GEFUNDEN
    Hi to all,
    I have been using DBedit for the past 3 months to transfer bouquets effortlessly via DBedit. I used to do this via laptop. It always worked perfectly and then one day out of the blue it says datei nicht defunden when i try transferring. I then tried to do it from the main desktop pc which worked flawlessly first time. After that the same error message datei nicht gefunden, which in english means file not found. It worked always and suddenyl stopped working for some strange reason. Can anyone please help me out as to how i can get it working again please?
    Thanks for reading, hope u can help!
    PS---have tried different bouquets SGT, b16 and all different dates but same message on all. Have heard it would be due to 2 devices with same IP but have checked and this is not the case. Confused.com
    PLEASE HELP!!!!
    Apr 2009
    Quote Originally Posted by msmmr View Post
    Confused.com
    PLEASE HELP!!!!
    you dont say what DBedit version you have tried and failed on
    you dont say what box you have
    you dont say what image your using
    have you checked all the options settings in DBedit
    have you checked the box ip against the ip in DBedit
    have you checked the user and pass test in DBedit
    are you using the right settings for your box
    have you checked the test ip connection in DBedit
    have you checked the right path for the XML file in options
    have you checked port 21 is written in DBedit options
    Oct 2010
    Quote Originally Posted by davvo View Post
    I have tested on several versions of DBEDIT now i am running latest version 4.1.0.0 i think before that was 4.0.1.2 and 3.1.0.1
    I am running DREAM ELITE 1.3.3D PHEONIX but same error on NABILO BLACKHOLE V0.12 BOTH ON A DM800HD
    THE BOX AND DBEDIT IP IS CORRECT AND MATCHING, HAVE PASSED THE TEST ON DBEDIT. SO HAS THE IP CONNECTION AND USER PASS TEST
    AM USING ENIGMA2 SETTINGS FOR MY BOX
    last 2 im an unsure about, the path for xml is "/etc/tuxbox/"
    and
    http 80 and ftp is 21. ftp type is passive
    Thanks for your reply
    Apr 2009
    after you get the file not found error
    in DBedit at the top click info then log
    it will tell why theres an error
    try DreamBoxEdit V 3.0.0.0
    try this
    ftp tab in DBedit click Receive Files from Dreambox
    send them to a new folder on your pc
    then try and send the same settings in
    the new folder back to dm
    Oct 2010
    try this
    there were errors receiving the files from the dreambox?
    Apr 2009
    try the info log at top of DBedit
    Oct 2010
    have attached error log mate
    V.I.P. Member andy91's Avatar
    Aug 2010
    East Midlands
    Take it you are using Enigma 1 bouquets and not Enigma2?
    Here is the Dreambox Edit Guide,double check everything mate.
    http://www.digital-kaos.co.uk/forums...75/#post810782
    Andy.
    Apr 2009
    now post a log sending files to the dreambox
    Apr 2009
    you had 1 Error
    Error retrieving file "userbouquet.dbe00.radio
    the rest Transferd ok
    check the target folder
    you will find that the files where received from the dm
    now send them back to the dm
    and post a log
    Oct 2010
    No worries guys, when opening files in dreambox edit, the files that i had received it said no sat xml file, i found another piece of software thats working a treat for now so hopefully it stays that way!
    Thanks for the help guys
    Oct 2010
    LOL, sorry again guys but the other software is shite and isnt working properly. DBEDIT is the one but i cant get it towork properly. When i open all the files received i get the error message attached. When i ftp i get the erroe message, datei nicht gefunden which is also attached. PLEASE HELP GUYS?
  13. #13
    Aug 2010
    East Midlands
    Have you tried other sets of new bouquets or asked someone to test yours?
    Andy.
  14. #14
    Oct 2010
    Quote Originally Posted by andy91 View Post
    Andy.
    Ok, ive got somewhere now,
    this mesage only came up when i created i used a certain set of bouquets. The error message has now gone and it is working. I am using b16 bouquets, it has 11488 in dbedit as the frequency however when it is ftp'd to the box the freq changes to 12560 for some reason? Any ideas PLEASE HELP?
    EDIT: GOT IT WORKING, NO PROBLEM, WILL ASK FOR HELP IF NEEDED. THANKS FOR TAKING THE TIME IN READING AND REPLYING TO ALL.
  15. #15
    Aug 2010
    East Midlands
    Sounds like there aae obvious errors with his bouquets.
    For now i would use an older working version of his bouquets and cut and paste any none working channels or use someone elses till these are sorted out.
    EDIT- Let us know what your problem was it might help others on the forum.
    Andy.
