Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
  1. #16
    Quote Originally Posted by ACDC View Post
    Couldn't do it with the times.properties file method. Strangely my 2011/3 Xentry doesn't delete it, and the error remains if I replace the file :S
    What was your "times.properties" method? Did you save two files to two different folders (and reboot)?
  2. #17
    DK Veteran ACDC's Avatar
    Feb 2011
    first of all: times.properties wasn't missing, and there wasn't a times.properties.ORIG file. Tried replacing times.properties with one I downloaded from here, it didn't help. Also tried copying a times.properties.ORIG file into the same folder, again with no succes. Though as I noticed foxdata's fix does the same thing though (replacing times.properties as I noticed it's last modified date changed), so maybe I've just done something wrong. But the problem is solved anyway
  3. #18
    Of course the main thing is that you got your SW up and running.
    Considering the fix you tried, you did not do anything wrong (as far as I can see) but you just did not do all the necessary steps. Now that your SW is running, perform a search for the times.properties file and you'll find it from another folder. You should have fixed this folder too when you placed the new files to the F:\Programme\Xentry\bin folder.
  4. #19
    Feb 2011
    I did as you told, searched for times.properties and found another one in C:\USERDATA\config\Xentry. But no one mentioned that here :P
    I guess I won't need that fix anymore because I tweaked the windows I installed Xentry on a bit. Now it automatically sets the date back to 2011.04.26. whenever the system starts up. Since I don't use any other apps or even the internet on that system, this workaround suits me fine, and Xentry will never notice the actual date change :P
  5. #20
    Hello Friends!
    I use Xentry 2011/7 version.
    My PC data is August 2011!I want to use laptop with right data but I think my xentry will not work.
    Pls give me a good and tested solution for make this job!
    i remember i use xentry 2011/7!
    thanks in advance!
  6. #21
    Jun 2011
    The Foxdata Xentry fix or solution is worked for my Xentry 07/2011. But required to save key in the LIcDir for reset key at Star Utilities.
    Many Thanks
  7. #22
    DK Veteran Carsoft2003's Avatar
    Mar 2011
    Algeria
    Thanks to foxdata your software work , I have test it in xentry 7/2011 work ok
