Hello friends I want swapping instrument cluster (( used )) on E65 MY2003 dose anyone know tell me please if is possible to make the used cluster virgin and how
Best regards
Best regards
You don't need to make it "virgin". All you need to do is write your VIN number into that replacement instrument cluster's eeprom and the mileage. You need an eeprom programmer that can read and write M35080 eeproms. If you still have the old dash just swap the eeproms.
Thank you for replay mate
I know where is the byte of the milage but I don't know where is the VIN byte
I have xprog-m and upa both original
I don't have the old dash also there is no old dash, just I buy two dash from junk yards and I want make it virgin and ready in case there are a car need it so I can programe it easy way by SSS
So if there are anyone can give me virgin file and tell me how to ears this eeprom I will be appreciated
Thanks in advance
no virgin just change vin in eprom and milage then code to car very easy. in eprom only last seven digits of vin.
regards
Thank you for response mate
You said I don't need virgin file just write the milage and VIN
but how to write the milage on this EEPROM, this EEPROM has registered data at first 32 bit and this is the milage location can't be write before erased so does anybody now how to erase this EEPROM or how to write the milage without erasing
Thanks in advance
Anybody have a UPA script file for the M35080 can support writing the VIN and milage
Best regards
bro
just swap the m 35080 to the new cluster
and be done with it.
