Results 1 to 4 of 4
    Default Hyundai Tucson CRDI - what mean P2113
    Hi friends, I have problem with Hyundai Tucson CRDI with DPF. x431 shown me fault code P2113 (in EDC) but without description. Max 3000 rpm, and check light on After erase, moment is better, but fault come again.
    What mean this fault code? This isn't accelerator pedal position sensor.
    Thanks in advance!
    ALGERIA
    P2113:
    Throttle/Pedal Position Sensor "B" Minimum Stop Performance
    Main throttle not work. Thanks!
    Oct 2018
    HELLO REMOVE THE THROTTLE BODY AND OPEN IT UP THERE WILL BE TEETH WORN OFF INSIDE --THE TEETH ARE PLASTIC YOU WILL NEED A THROTTLE BODY--HOPE THIS HELPS
  5. The Following User Says Thank You to Rabgunners For This Useful Post:
    rtbdiagnostic (22nd July, 2019)
