Results 1 to 10 of 10
    Default help me please in u009 and u0010 santa fe code
    hello
    think u for helping me for adbvance
    i have two error code u0009 nand u0010 in a Hondai santa fe 2009
    The Santa fe stop immediatly ,the MIL light is on. After 1mn it's OK the mil is on, after reset the MIL if the motor run over 3500rpm it's stop immediatly if the vehicle rolls, not if motor run aver 3500 rpm and vehicle immobil
    Thank's
    The fault codes describe problems with the High Speed can-bus and the Mid-speed can-bus.
    What scanner are you using to read those codes and which system (abs, engine, etc) gave those codes?
    hi think you for trying to help me
    i use the Actia multidiag scanner and it appers in engine fault code (with scantool function)
    oh it is an hondai santa fe 2009 diesel motor 2.2crdi (D4EB code motor engine)
    ALGERIA
    U0009=High Speed CAN Communication: Bus (-) shorted to Bus (+)
    good luck
    Scantool? You mean an EOBD/OBD2 generic function?
    If you don't have Hyundai specific software, find somebody with a Launch or Carmanscan, or have the dealer pull te codes.
    THINK YOU MR.
    CAN ANYONE HAVE THE ENGINE WIRING DIAGRAM PLEASE,,,,,,,,?????????
    ALGERIA
    ecu pin K-83=CAN Low-------plug diagnostique pin14
    ecu pin K-84:CAN High------plug diagnostique pin6
    OH THANK YOU VERY MUCH FOR HELP
