Results 1 to 7 of 7
    Jun 2011
    Default WiiFlow problem with ocarina
    I have googled for the cause but cant find it, basically WiiFlow will download cheats fine for any game I have except Monster Hunter Tri (RMHE08). I click settings and cheats, download and it says "Download not found." but the address it gives for the cheats has a text file with atleast 900 cheats for monster hunter tri: "http://geckocodes.org/codes/R/RMHE08.txt" so I even saved this to the txtcodes folder on the SD card and it still wont find it, keeps showing the download cheats page. So what do I do to either fix this or get the cheats up? its just cause on one of the quests its bugged and I cant get all 30 mushrooms only 13 so I just need the item slot 1 = 20 code.
    V.I.P. Member ck-ok's Avatar
    nottingham
    Quote Originally Posted by Konkor View Post
    is the game ntsc/us or pal as those cheats are for the ntsc version have you tried the pal cheats?
    try downloading from a different loader like gx as those cheats might be corrupt
    Jun 2011
    Using USB Loader GX it finds the sd:/txtcodes/RMHE08.txt file and works perfect can load more than 2 cheats which some people said would crash. Going back into WiiFlow no txtfile comes up :/.
    nottingham
    thats typical of modding what works on one loader may not work for another at least you can play it through gx so i guess problem sorted.
    DK Veteran Keithuk's Avatar
    Aug 2010
    England
    Well according to USB Loader GX Text the cheat txt is saved in Cheatcodes Path - SD:/codes/. There is an option in the settings to use
    Ocarina-- Turn on/off the ocarina cheat engine. You need gct files in the cheatcode path mentioned earlier.
    I've never tried it on WiiFlow?
    Keith
    2010 Golf GTD (170)
    Jun 2011
    Weird, I have a text file in SD:/txtcodes/RMHE08.txt that has the cheats stored in and I didnt have any GCT file in the SD:/codes/ folder. WiiFlow never found anything online or in the directory I couldnt find any options either to cheange the directory or to search the folders. It works perfect on USB Loader GX though and loads more than 2 cheats at a time so for anyone with this problem just use GX Loader and make sure to set the IOS to 223.
    Aug 2010
    England
    I have these cheat codes setup on USB Loader GX but everytime I run a game it says cheat code not found/available. What happens if there is a cheat code do you have to type them in game options or does it list the available codes?
    Update:
    I've just checked the SD card and there is a RZTP01.TXT in the txtcodes folder but its 0 bytes, RZTP01 is Wii Sports Resort, the codes folder is empty?
    I downloaded Wii Sports Resort but it wouldn't work it just jumped back to the Wii menu. If you Google this problem and it talks about alt.dol thats all. Plus you have to let the 3 minute MotionPlus intro video finish.
    So I bought this of eBay and now noted this video has been played it now plays of the USB drive. The slight glitch is it save 2 save datas for this game. I moved one to the SD card and I moved the wrong one I deleted the other one and copied it back from the SD card now I have my original scores/settings.
    Keith
    2010 Golf GTD (170)
