Results 1 to 15 of 25
Thread: 2004 Golf V 1.9TDI (105 hp) engine ecu( eng code BKC )
    z786's Avatar
    10 Steps Ahead of You
    206
    Exclamation 2004 Golf V 1.9TDI (105 hp) engine ecu( eng code BKC )
    Car complains of engine speed sensor fault, has been replaced twice.
    iv read somewer that there is a fixed flash file available for these
    if some1 can supply it would be great
    "I always tell the truth. Even when I lie"
    "We Taking Over, One City At A Time"
    ALGERIA
    what's hw and sw number?
    also once fought with this problem, these engines were 3 types of sensors two gray and one black, you have to perfectly fit the sensor, in my case I had a substitution of some of the same and also did not work, it was only later I put another and work as you had gray you have a 50% chance of you can match the correct
    z786's Avatar
    206
    here is the flash file from galletto
    v1037369564
    .0281011478
    BPG-81031.01.04123456
    818840651.
    .WVWZZZ1KZ4W075522.
    .0281011478
    .R4 1,9L EDC
    can any check for me plz
    remove dtc codes will not solve the problem
    z786's Avatar
    206
    the car has had 3 crankshaft sensors
    in ross tech wiki it shows that these ecu's have been given a new upgraded flash and also given extra earth installation
    ALGERIA
    the dump that you sent is 100% original
    may be you have probleme with wires!!
    i don't anderstand!! in 1st post you speak about speed sensor fault
    and now you say 3crankshaft sensors was remplaced
    they are very different this 2 sonsors!!!
    z786's Avatar
    206
    Quote Originally Posted by grinovsky View Post
    The Engine Speed Sensor (G28) is also used as a reference sensor for the crankshaft position and correlates with the Camshaft Position Sensor Bank 1 (G40) and Camshaft Position Sensor Bank 2 (G163).
    see section special notes
    16705/P0321/000801 - Ross-Tech Wiki
    ALGERIA
    dtcP0321:crankshaft sensor
    chek 5v betwen pin1 and pin3
    pin1 crankshaft sensor--------pin B42 ecu (+5v)
    pin2 crankshaft sensor--------pin B58 ecu (signal)
    pin3 crankshaft senso________pin B57 ecu (gnd)
    if the probleme is in flywheel (volan moteur) you shuld see the signal by using osciloscope to make diagnostic
    no relation with speend sensor
    z786's Avatar
    206
    so whats the speed sensor then mate
    ALGERIA
    the speed sensor is emplanted in gearbox to mesure the speed of the car when move(km/h)
    and crankshaft sensor is emplanted between engine and gearbox to mesure the speed of engine(rpm)
    z786's Avatar
    206
    im sorry mate, going to have to disagree with you on this one
    on a VAG car, the "Engine speed sensor" IS the crankshaft sensor as it gives the ENGINE speed, not the vehicle speed, the vehicle speed (k/mh) is taken from the ABS sensors
    i even quoted you a section from ross tech and gave you the link
    "The Engine Speed Sensor (G28) is also used as a reference sensor for the crankshaft position"
  13. #13
    Apr 2011
    in lebanon
    47
    Default about golf v
    Hello Dear DK FRIEND (z786)
    1) I dont know if you use scan vas ? this device is verry imported about your problam ,you can use (guided fault finding) & in this test you can get all information or manual about you fault & how you check all sensors ,and in the system can you do update ecu if your ecu needed update,
    so i wish for you Good Luck.....
  14. #14
    z786's Avatar
    206
    iv used VCDS which is the next best thing
    car while driving cuts out, then doesnt start for ages
    it gives error code for engine speed sensor no signal
    from the research i have done it shows engine flash needs upgrading
    heres the sections from rosstech site
    "When found in a 2004 VW Golf, Jetta, or New Beetle with 1.9l TDI-PD (BEW), check for TSB 2010461 (01-07-45 formerly 97-05-03) or 201463 (01-07-44 formerly 97-05-04) calling for a flash update to the ECU and a secondary ground installation."
    Has any1 got an upgraded flash please?
    or any other solution
  15. #15
    mastaflex's Avatar
    Jan 2009
    FR47310
    184
    sometimes this fault is not caused by the sensor itself and you replaced it twice. it happen to me once on a GOLF MK4 and the problem was the target on the flywheel. but to inspect this you have to remove gearbox and see. for my case target was totally damaged (how ? don't know)
