Results 1 to 14 of 14
    Jul 2011
    Default DM800HD SE no ca found, dreamup doesnt work
    Hi All,
    I just got my DM800HD SE (Latest Version).
    It came with an image on it but I decided on the advice of others to play around with a few images.
    I flashed about 2 different images successfully. I decided to try another. I flashed the image, the box rebooted and now I get a "RO1: NO CA FOUND" (Note the ER is missing at the start).
    The DM800 HD SE doesnt have an RS232 port. It has a USB B-Type connection on the back.
    So using this I can establish a connection using DreamUp and connect to the box.
    DreamUp uploads a flash-loader onto the box but freezes at "upload completed waiting for acknowledgement" and then on the LCD of the box, the top half of the DREAM logo appears and underneath it "* ERR01: NO CA FOUND" and just stays like that.
    What are my options?
    Jul 2011
    Default 6 hours later.....
    After spending a solid 6 hours trying to solve this I finally got it!
    The trick is to use Sunray Flashup for DM800 SE instead of DreamUp.
    It can be found here:
    SUNRAY-FlashUP.rar - 4shared.com - online file sharing and storage - download
    (Sorry if Im not supposed to post links like that.)
    As the DM 800HD SE is relatively new and will most likely be very popular in the future it might be worth while for the mods to write up a sticky explaining how to solve CA NOT FOUND on DM800 HD SE.
    Hope this helps anyone who finds themselves down the same road.
    Regards.
    Jun 2011
    Glad you've managed to sort it out and thanks for advising others how to go about doing it as well! Touch wood up to now I've not flashed a wrong image yet but I always like to read these type of posts for when I inevitably get the same problem!!
    Jul 2011
    yeah nice to share, just in case i end up ondey with it now know what to do.
    Nov 2008
    if you look at this thread, you will see all these problems have been had and resolved.
    main thing is not to flash the latest original image.
    http://www.digital-kaos.co.uk/forums...-hellp-215057/
    Jul 2011
    Tirana
    Hi every one
    I have problems on dm800hd "tuner failed" on hd channels. Pls help me how to fix it
    Nov 2008
    how good is your signal and quality strength.
    does it work on the feeview hd channels.
    else do a full manual scan.
    you should also post on a relevant thread. this is not the correct thread for your issue.
    Mar 2012
    HI people, have tried the procedure above of clearing NO CA found with Sunray-FlashUP but i get on the status a message Upload completed, waiting for acknowledge,,,,and then nothing happens after that, what is thw next step? I also have a dreambox DM800HD SE clone
    DK Veteran lincsat's Avatar
    Jun 2008
    Do you have the mini-USB connected and the correct driver loaded?
    I use Optiflasher rather than Dreamup/Sunray-Flashup and used the USB driver from the Dream media site
    Aug 2008
    Hi, have you got dm800se with mini flash at back ?? if you do its so easy to reflash, no need usb cable no need dreamup etc
    just hold in mini flash button and re apply power and will get IP address and then just flash as normal its such a great feature dont even need to move box
    Apr 2013
    Hi Manner,
    It be great if you could tell e did u just flash with Sunray or did you go to web ip and then do it that way I've the same issue and been at it for ages really struggling
    I couldn't get DreamUp to work on my DM800 when I got the NO CA error. But this program did work & supports the SE as well. Just select your boot loader > Click detect ports and select the one you need when serial/miniusb is plugged in > Hit start > Power up your dreambox > Bobs your uncle.
    NCF 2.1 - NCF-SIM2-v2.1.rar
    Mirror - http://www.filedropper.com/ncf-sim2-v21
    Hope this helps anyone who has this error.
  13. #13
    V.I.P. Member chic.'s Avatar
    Feb 2009
    glasgow
    well done on your success m8 but the se has'nt got a com port you need a mini usb or a flash switch on the back .
    if i helped hit the thanks btn
  14. #14
    Quote Originally Posted by chic. View Post
    It comes bundled with bootloaders for DM800 and DM800SE - It just says detect ports on the program so I'm thinking it supports the mini USB too as well as COM. Just listing the steps I done on my DM800 for any newbies like me .
