Results 1 to 15 of 28
    DK Veteran VTS_Tibi's Avatar
    Default Ford Focus II. 1.6 TDCI - dpf removal
    Hi Guys!
    On Monday I'll have to remove the DPF from a Ford Focus II. 1.6 TDCI.
    Could you please tell me what's involved other that the pretty obvious remove the DPF physically"?
    I will have to read out a dump from the ECU, but which one? Is this info stored in the flash memory, like a AM29F400BT or such?
    Would I be OK with EEPROM programmers, as I do not have Galletto or such....
    And if the dump is given, just use ECUsafe, and let it remove the DPF function?
    And after? Should I remove sensors, or do something else?
    Sorry for asking too many questions, but I've never done a DPF removal before and I think it's better to ask
    Regards,
    Tibi
    Ecusafe - not work. Winols - work super - DPF off 100%. I made 2 ford 1.6TDCI.
    It is necessary to disconnect a black box under the back we correct sitting, and it is possible to disconnect the gage of a difference of pressure (to which there are tubules).
    Thanks for the info!
    Could I use an EEPROM reader to read out the flash content, or would I have to read out something else?
    Only flash. BDM100, MPPS, KESS-clone(wery good)
    so, can't I do this, by simply desoldering the flash memory from the ECU and then reading it out? - don't want to buy an other interface again!...
    Okay, the car is here!
    I had a quick look around, and it seems like I could get the following tools here:
    -Galetto
    -MPPS
    -BDM 100
    Could the Galetto do this job? - as that would be the easiest to source, and I could buy one today - for the other I would have to wait!
    BDM 100 confirmed to work with this car! - I would get one immediately, but with this I could only read the new cars which use that new type Motorola flash...
    Galetto - would that work?
    Usa
    need to disconect presure sensor? i do not disconect presure sensor,i read it with mpps ,and did it with ecusafe2,now i have fault P1187 Variant Selection,but when is turn on and turn off fault disappears.
    Probably ECU coding is gone due to reflashing via OBD.
    Usa
    and how to do coding now? help
    With VCM IDS (Ford tester)
    Usa
    i want to write new calibration file in focus but i have this file 7M51-12A650-UG in calibration file but how to update ford ecu?
  13. #13
    Usa
    i write back original file to ecu but error still are,my mpps broken ecu? i do many peugeots with mpps and good,trouble code p1187 vaariant selection,injectors codes good
  14. #14
    Injector coding is not the only coding, at least that's the way it is on PSA. There is also ECU coding: type of gearbox, etc
  15. #15
    Usa
    all ok
