Results 1 to 7 of 7
    Senior Member zee24's Avatar
    Jan 2011
    Default No sound on HD Channels on Blade BM7000s
    hi i have a Panasonic viera HD tv i have connected my blade to it and it works fine apart from the HD channels and Sky1 which don't have sound but the picture quality is fine. Does anyone know how to sort it out? all the other channels that aint HD are fine.
    DK Veteran Rodbouy's Avatar
    Jul 2010
    I have heard a few tvs had this problem, Im sure you need to mess about with the audio settings on the tv and it will sort the problem.
    Cant think off the top of my head but mess about with them on the tv.
    DK Veteran billy2's Avatar
    Jul 2008
    some where over there
    i have the Panasonic viera m8 and had the same probs with the dream 800 i had to go into settings on the dreambox and trun on ac3 downmix to on to get sound working
    please press the little red THANKS tab
    if I helped if not press the green tab to tell me to f**Koff
    Sep 2008
    yep,check audio settings and alter in sat box,i think it may default when powered off at back so will need redoing.
    DK Veteran lincsat's Avatar
    Jun 2008
    The TV may not be able to handle Dolby over HDMI, there should be an audio setting on the TV to change.
    Jan 2011
    thanks guys for all the helpful info i will have a look and will get back to you cheers
    Jan 2011
    hi sorted the sound prob, lincs was right the tv setting was on HDmi sound but when i changed it to Dolbi it was all fine
