Results 1 to 8 of 8
    omglol's Avatar
    Jan 2009
    Europe
    Default Toyota Yaris ABS problem
    Hi!
    I have Toyota Yaris, make year 2005, with ABS problem. Diagnostics throws codes C1246 and C1223. Quick googling suggests replacing whole ABS pump/controller. Does anyone know something more about this problem?
    Liteace's Avatar
    Mar 2009
    On a rock
    Check brake light switch and also master cylinder pressure sensor
    - Sent from my iPhone using Tapatalk
    omglol's Avatar
    Jan 2009
    Europe
    What to check about brake light switch? All brake lights are working normally (left, right and 3rd brake light).
    About this master cylinder pressure sensor ... where is it located and how to check it?
    Many thanks!
    omglol's Avatar
    Jan 2009
    Europe
    Is this perhaps the sensor marked as "Oil pressure sensor, 74.7 (761,55)" in this picture?
    Liteace's Avatar
    Mar 2009
    On a rock
    Quote Originally Posted by omglol View Post
    Many thanks!
    The brake lights might be working well BUT the switch will do brake lights and maybe have 3 or 4 pins the others are for ECU. The diagram you posted is for a 2003, 4runner ?????
    omglol's Avatar
    Jan 2009
    Europe
    Yes, I know it is for 4 runner ... I didn't mean that is precisely exact part, but just for reference ... will check the brake light switch now. Tnx.
    omglol's Avatar
    Jan 2009
    Europe
    Tried changing brake light switch .. no joy ... fault codes cannot be cleared, tried with 3 different diagnostic scanners ...
    omglol's Avatar
    Jan 2009
    Europe
    Hmm ... looks like I'll have to get used ABS module and try it out. Does anyone know if these modules are VIN coded or something ... or are they plug & play?
