Results 1 to 15 of 24
    Default Toyota Corolla 2010 immo off
    Hello everybody
    i need i immo off dump for corolla 2010 1.6 , i have a dump work good in corolla 2008 and yaris for eprom S93c66A .
    i try to use it in corolla 2010 didn't work but the eprom in corolla 2010 not s93c66 it is RH56 in the same location in ECU .
    also the the immo box have a problem so i need immo off file.
    i try to use immo box for 2008 using AD100 i have reset the immo and match the keys and immo Lamp go off but the engine still not start .
    Thanks for all
    Best Regards
    Hello
    her the the dumps for ecu and immo box for the vehicle.
    hope to find immo off
    Best Regards
    You need to match ECU to Immo box by jumping pin4 and pin 13
    Sent from iPhone 4S
  4. The Following User Says Thank You to sogaro For This Useful Post:
    taherdiafi (27th June, 2020)
    Nov 2010
    more info about ecu
    USA
    u can swap to 93c66 no problem
    Program and enjoy
  7. The Following 17 Users Say Thank You to Mezo For This Useful Post:
    ali kaptan (18th March, 2025), art64 (9th November, 2023), carlab237 (27th June, 2024), DANILLO (6th February, 2019), DIGITALSIX (25th September, 2023), drissdiag (12th November, 2019), dshimkute (2nd July, 2018), foxdata (1st April, 2020), GrahamR (7th October, 2023), jkahlon (8th January, 2025), keymax (4th November, 2018), KRAUSER (31st March, 2020), mahmoudbm (21st November, 2022), MARIKO (6th July, 2024), NORSHAN (13th May, 2015), pollito128 (13th September, 2018), shtyrya2 (7th April, 2025)
  8. #6
    Hello Mezo
    You mean that change RH56 eprom in 2010 ecu with 93c66
    or write the content of 93c66 immo off to RH56 eprom in 2010 ecu.
    i have try to change the RH56 with 93c66 but no starting.
  9. #7
    bram380's Avatar
    Indonesia +628153111774
    please keydata 4d70
  10. #8
    pinkfloyd5eg's Avatar
    DARK SIDE OF THE MOON
    @magdyman >>> You need to match ECU to Immo box by jumping pin4 and pin 13 as posted above by our friend "sogaro" ,
    then , if you still have the problem then try to virginize the immo box and match new keys .. (immo off is not easy for this car) , this only my opinion ,
    good luck.
    << KEEP LEARNING W.O LIMITS >>
    2 Simple Methods To Say Thanks on DK
    Press Thanks _OR_ Add Rep
  11. #9
    Hello
    Mezo idea was good to change RH56 eprom with 93c66 and write immo off dump to 93c66 .
    The Engine start good.
    Thanks for all
  12. The Following 7 Users Say Thank You to magdyman For This Useful Post:
    Bnh979 (7th March, 2025), bonecrusher (17th May, 2016), carlab237 (27th June, 2024), DIGITALSIX (25th September, 2023), dshimkute (17th July, 2018), Jonatanfunes91 (3rd August, 2022), Mpho2014 (29th October, 2022)
  13. #10
    Sep 2018
    Greetings, friends what do you suggest is to use 93c66 memomoria with inmooff installed ?????!
  14. #11
    AutoGeek's Avatar
    Jul 2016
    Northern Cape,South Africa
    Quote Originally Posted by Mezo View Post
    Program and enjoy
    Hi. is this immo off for Corolla Professional 2010?and is it true that you can change eeprom from 93c56 to 93c66?
  15. #12
    Mar 2020
    Default TOYOTA COROLLA 2010 1.8 LTS. IMMO OFF FILE.
    Hi everyone, I know this thread is a little bit old, but, it helped me pretty much. So now I want to share with you an immo off file for Toyota Corolla 2010 1.8 lts. PCM 89661-02F51 and similar, with eeprom 95080. It's 100% tested and functional. Enjoy !!!
  16. The Following 22 Users Say Thank You to KRAUSER For This Useful Post:
    ali kaptan (18th March, 2025), art64 (9th November, 2023), Bnh979 (7th March, 2025), borix (8th April, 2022), carlab237 (27th June, 2024), dEONBE (3rd January, 2024), DIGITALSIX (25th September, 2023), ecufix (30th June, 2020), foxdata (1st April, 2020), GrahamR (7th October, 2023), jakesman (13th July, 2024), jenya (31st October, 2022), jorgedosreisfra (27th January, 2025), jupteck (11th June, 2022), kmajor2 (17th June, 2020), krimoalg (6th May, 2023), lanefi (9th November, 2021), MARIKO (27th October, 2024), Sake (25th August, 2024), vaselo (27th April, 2020)
  17. #13
    Aug 2015
    Default Tanks
    Thanks thanks
  18. #14
    Aug 2015
    Thankes thanks
  19. #15
    Jul 2020
    Hi Dear , could send me that immo file because I can not download it PLZ
