Results 1 to 8 of 8
    wzsola's Avatar
    Hungary
    Default Peugeot 1007 door problem
    I have a problem that shit car.
    The passenger door doesn't work. I check the motor, is ok. I check the fuel flap switch, working. The bsi 1 fault, passenger door, door contact switch ground problem. I check the wiring and the switch, everything ok. But I think this fault is not important because the door not work absolutely. Have anybody any advice?
    Thank you any help.
    wzsola's Avatar
    Hungary
    When I try the door the bsi switching 12V the door module. What conditions are necessary for the operation the door?
    Thank you any help.
    Aug 2011
    I know it's an old post, but 99% of door failures come from the in-door actuator that becomes slow or fails. It puts the door in failsafe mode and prohibits further operation until the door is serviced and the error reset with PP2000 or a BSI reset.
    I hope I helped people that are looking into this similar problem.
    Member afmotorsport's Avatar
    Portugal
    Do you check the rear cable position switch?? Check it
    Meat-Head's Avatar
    Quote Originally Posted by yvesdm3000 View Post
    I know it's an old post, but 99% of door failures come from the in-door actuator that the error reset with PP2000 or a BSI reset.
    ON TOPIC:-
    Yes second that, as for reset slam door shut then button on dash hold for a few seconds
    approx 44 UKP + VAT dealers normally keep on shelf.
    OFF TOPIC:-
    DK is such an amazing website you often miss things
    bursuc's Avatar
    Oct 2011
    inside MCU
    Anyone has some wiring diagrams for door control module ? my door is not sliding aswell
    Please help
    Dosen't matter how hard is to repair something as long is made by humans and thinked by humans !
    Aug 2011
    I find it easier to use PP2000 to diagnose 1007 door problems. It's not that the software will tell you what's wrong, but you need to make a little scenario, first test it on the good working side and then you go to the bad door and whatever is not working in the scenario, that's where your problem usually lies.
    -Yves
    DK Veteran juniormaxxx's Avatar
    Aug 2010
    croatia
    all myne cases with door trouble on this can is small actuator in interior handle...similar to vw for open trunk..when its get slow sistem somehow gets in protect mode...in 10 case off trouble 9 is that small actuator
    If I was usefull be sure to thank me.......if I was not just do nothing, I can shot lighning and use mind tricks through internet........yea i can....
