Results 1 to 14 of 14
    gomarota's Avatar
    Default fiat doblo 2001 1.9 jtd immo off
    Hello, i need to do this immo off, its posible done via MPPS or i have to unsolder and read the eeprom soic 8 pin? i have not the car yet, i need to know first if i will be capable to do the work
    can be done with xprog 5?, i have bdm too
    thanks!!
    LOVE DK!
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    Read flash with mpps
    Ecu is with two plug, or five plug?
    Regards.
    gomarota's Avatar
    Thanks really for both post!
    I will read flash with mpps, the problem is i have to do all in 2 hours because its 200km far away from here.
    The ecu i dont know yet if its two plug or five plug.
    So its stored in flash? can you tell me with with sw can i do this work? (if you dont want to tell me i will understand )
    thanks mates!
    LOVE DK!
    gomarota's Avatar
    I offer money for this info. I have to do it.
    LOVE DK!
    lupu_sandu's Avatar
    Far far away
    So, where is flash?
    Bdm, do not serve for this ecu, flash 29f400 for sure.
    If ecu is with five plug, car is euro 2, and immo-off do not posible with dump 29f400, with eprom serial 8 pin (24c04) only posible immo-reset.
    I know immo-off is possible only with emulator.
    If ecu is with two plug, immo-off is posible in flash 29f400.
    Regards.
    gomarota's Avatar
    tomorrow i will read flash on car,
    so immo-reset is not the same that immo-off? whats the difference?
    will pray for be five plug ecu
    LOVE DK!
    Quote Originally Posted by gomarota View Post
    I supose you mean:
    "will pray for be two plug ecu"
    two plug=immo off in flash.
    five plug=immo off, only with emulator.
    Immo off:
    Other immobilizer system (keys, code box, antenna, etc.) to be in bad condition, car starts anyway.
    Immo reset:
    Other immobilizer system (keys, code box, antenna, etc.) must be in perfect condition, or car will not start.
    Regards.
    gomarota's Avatar
    here is the ecu id,
    Fiat Hawdware Number 46737473
    Bosch Hardware Number R04010036
    Bosch Hardware Id 0B
    Bosch Software Number R2L01
    Bosch Sofware Id 0C00
    Fiat Identifacation Number 3F.003
    Fiat Iso Code C207019837
    Fiat Tester Number LUCAS001
    Programming Date 31/05/2001
    dont know why i couldnt read with my mpps, i have defective i think, the immo is in flash or with emulator?
    thanks!
    LOVE DK!
    lupu_sandu's Avatar
    Far far away
    Remove ECU and open. Look at serial eeprom
    Ecu lucas is for 1.9D, not for 1.9 jtd.
    I do not flash eprom.
    Normally serial eeprom 25080.
    Regards.
  13. #13
    gomarota's Avatar
    Ok, thanks, i will ask him to get the ecu out and give me, i will post here the 25080 eeprom if he give me the ecu.
    Thanks both mates!
    LOVE DK!
  14. #14
    skens's Avatar
    Zagreb,Croatia
    hi
    position eeprom
    regards
    Please dear members push the button thanks and reputation button(stars)
    do you need help? fill it in !!!
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    ECU type and number:
    Memories :
    https://www.digital-kaos.co.uk/forum...63#post1660863
