hey catseye. i tried using dreamset but im having difficulty using the software. when i select open and try to load you bouquets, theres loads of files. which one do i select. theres a file called "lamedb". dont know what to do, any help anybody?
i can send the files over via dreamboxedit, but bouquet does not load properly. for example in the favourite section normally it should be split up into different genres e.g entertainment, sports however when i transfer the files in the favorite section i get loads of <n/a>.
why is this, any help?
Yes m8 select the lamedb file-make sure under the 'set up' tab its set for enigma 2
Whilst its transfering you should a little image on your pc screen of files transfering from pc to sat box
if you see the channel lists on screen & its 'greyed out' it means your satellite configuration isnt set up own your sat box
Just make sure all the sats you want to view are set to the same lnb
select the favourite section of the settings using blue button on box remote to navigate around
enjoy
I still can't get it to work properly. Alot of <n/a>. I'll record a video to show what I'm doing and put it on YouTube.
Is it possible to download your bouquet directly through the dreambox via TS panel. If so how???????????
I got pheonix edition 1.33 2.1 sim botloader 82 software.
Sent from my HTC Desire using Tapatalk
Dm800 HD pro sim 2.1 bootloader 82. Where can I download it from direct through box??????
Using dreamset v2.34 software
Click on set up tab, then connection
Configuration -type in your box name
Box Ip= IP of your sat box
User name =root
Passsword= what ever you choose
firmware=enigma2 version 4
Save configuration then ok
Open up unzipped file so its showing settings on your pc screen
Click transfer -at top of mini screen that appears it should have your box name & its ip address
Click write
You should see image of file transfeing to box
followed by complete message
Try rebooting gui on box & follow previous posts if channels are greyed out
It might be worth your while if this fails to check your firewall is blocking it
I downloaded one of your bouquets direct through the TS panel. Thanks
Catseye Enigma2 Settings File 75 East-58 West 24.12.2011
Includes most recent updates from KOS site & more..
Enjoy & Merry Christmas
Merry Christmas to you too!
I seem to have some problems with CrossEPG downloader not updating the information for the channels, in other words i cannot scroll through the channels once i've installed the Catseye listings and downloaded with CrossEPG, the channels just show as blank. Is there another downloader or does anyone have any settings i could use for 28.2e and 13.0 please?
Feel free to move this post if its not in the appropriate place too
Ah sorry, forgot to mention its a Qbox HD mini i'm using, however i was searching for this bouquet and couldn't find the relevant Qbox section
