Results 1 to 3 of 3
    mastaflex's Avatar
    Jan 2009
    FR47310
    Default ecu swap citroen siemens SID801A
    hi all::
    i would like to swap ecu on a citroen berlingo HDI with siemens SID801A. would like to know if only swapping eprom 93c56 would make the engine start?
    mastaflex's Avatar
    Jan 2009
    FR47310
    hi all:
    this thread should be closed, problem sorted. virgin 93C56, reset rolling code on 29F400 + calc checksum , reprogram ecu on car with pin code and options and all ok
    Member autoperfect's Avatar
    Default SID803
    PLS if you send methe old and new vergini file for this ecu.thanks
