Results 1 to 7 of 7
    Senior Member makadam's Avatar
    Nov 2010
    EUROPE
    Default OPCOM Interface communication error
    I have a new OPCOM (green plate with 8 releys) and this window appear when I try to make any diagnostic test. Firmware version is 1.39 and I I'am using 082010 and 081016 that came on CD with the cable.
    BTW hardware test PASS and also when I use FUT everything is fine and all fields are fill with standard info like some working OPCOM.Also there is no reley CLICK and no window prompt for activation!
    Some solution?
    Liteace's Avatar
    Mar 2009
    On a rock
    I had the same problem, what I done was put it in the rubbish and spent 30 quid on a new one and it worked
    Nov 2010
    EUROPE
    Yes that is the easy way but I want to repair the unit, maybe someone find the solution.
    DK Veteran manocao's Avatar
    __________________
    China: OPEL Tech2 non-CAN multiplexer USB, OP-COM USB, OBDII Elm327 USB, VAG-COM 409.1/VCDS Lite 1.0 KKL USB
    Homemade: UNISCAN Visa 1.83 RS-232, Renault XR25PC USB, BMW KKL USB, Nissan Consult1 USB
    Nov 2010
    EUROPE
    Thanks monacao I will try to reflash pic with external programmer!
    t77's Avatar
    Poland Lodz
    Hi , I had similar trouble with OPCOM firmware 1.39 (without relays version)...after connect to car (K line) every works ok,but for example connected to Astra H (CAN line) appears message: Interface Communication Error..Test interface done , FUT done ...I make reflash PIC and compare HEX with good file...no difference ...ok I was more search why do not work properly and I find reason ... GAL16V8D after replaced from new one OPCOM works fine ,,.I was try read GAL but no success, probably is secured ..My question is ..Is who have dump from GAL 16v8??? Thx
    Top Poster + mladen76's Avatar
    By the see
    Quote Originally Posted by Liteace View Post
    It is a good solution
    But you can get it for mutch cheaper,under 30 usd,personaly I woud always pay a bit more to get more quality but that is hard to find,usualy you get same product for more money....
