Page 4 of 12 FirstFirst 123456789 ... LastLast
Results 46 to 60 of 166
  1. #46
    Top Poster GSI2's Avatar
    Feb 2009
    moon
    Quote Originally Posted by billboard View Post
    ok m8 i have
    1. delete F:Programme/xentry/bin/StarmodeWrapper.ini
    xentry start but without icons in the middle left side
    2. i return StarmodeWrapper.ini and copy DB_memebr file to C:\Programme\SDnetControl\properties.xml
    xentry fail 2221-0
    3. i have the error only if i dont start SDNC
    4. if i starup SDNC (with larg icon on systray) then xentry wake up and work with all icons and etc
    Began making changes to try understand what could make it work and now I only have 1 icon
    Thats got to be a way
  2. #47
    Sep 2011
    Orlando, FL
    Can you upgrade 01-2011 to 07-2011
  3. #48
    Feb 2009
    moon
    Quote Originally Posted by ahorvath View Post
    I always do clean install but I think you can.
  4. #49
    Default Thanks mr. Zolookas
    Quote Originally Posted by zolookas View Post
    This is a guide for installing DAS 07.2011 (and probably 05.2011) software on any computer running Windows XP SP3
    Password: Qutomotive
    Big thanks goes to Impactops, Qrius and strda50es for solutions, ideas and testing!
    If you have any questions please don't PM me.
    I don#t know who are you mr. |Z , but let God bless You . I did install today 07.2011 without any troubless at all. Thanks.
    Every day, every hour I like. Still alive.
  5. #50
    Bogota Colombia
    Default DAS Large Hard Drive Fix
    hello
    i need the DAS Large Hard Drive Fix for install das 07-11
    my hard drive larger than 120GB ( 150GB)
  6. #51
    impactops's Avatar
    Quote Originally Posted by antioqueno View Post
    hello
    How about telling members what you have tried and what you haven't tried so that they can suggest to you things to try rather than you coming back and telling them you have tried it and it didn't work
    Impactops
  7. #52
    Feb 2011
    GB
    Default das xentry 03.2011 work with machine ACTIA MULTIPLEXER FOR MERCEDES BENZ
    hello zoolokas.
    I first thank the guide.
    at the time and I contacted you through grinich 6-8 months ago but had to leave for work.
    and now I've come back onto the installation of the machine for mercedes benz multiplexer ACTIA 05/06 years
    Not for this interface if it will das 03.2011 xentry that's the version I'm trying to install and about 8 months ago I downloaded along with your guide (newguide2e)
    Because 11.2010 try to test version and I do not work, and stopped trying to run the setup Stardiag directory. So this morning I tested with version 03.2011 and seems to start the installation.
    the question is whether valid for the machine that I mentioned that's the question after the installation that takes time.
    I do use for the version of das-xentry 03.2011 to download about 6-8 months ago with your guide that you download called newguide2e or ultilizo latter guide you uploaded to the forum and that is more current but it is put for the version of 05.2011 and 07.2011 xentry das
    Although the version I downloaded 07.2011 not yet, and the download version is in 05.2011
    ACTIA will work with the machine mercedes benz multiplexer.
    Or use the above guide or the new guide before starting the installation.
    Because all day yesterday I messed with it and I was not until this morning I started the version 03.2011 and that if the installation starts
    thank you very much for responding
  8. #53
    Jan 2011
    HI guys! Please help me: Xentry 07.11, error 2.75-3.175
    times.propeties.ORIG change times.propeties and doesn't help.....
  9. #54
    Hi....
    I install the 07-2011 fresh copy using Mr. Zolookas instruction. Working perfect. Now I am in trouble to install the WIS.. 2nd CD.
    I tried those help what you guys mentioned, but somehow its not working for me... or I do not understand it right... Also I do not have HKEY_LOCAL_MACHINE\SOFTWARE\STAR DIAGNOSE\COMPACT3
    option after the installation...
    Anybody has a solution how to install the wisnet?
    If yes please let me know..
    Thank you again for the help Mr Zolookas
    Savos56
  10. #55
    Feb 2009
    moon
    Quote Originally Posted by savos1956 View Post
    Hi....
    Savos56
    You must have HKEY_LOCAL_MACHINE\SOFTWARE\STAR DIAGNOSE\COMPACT4 if you don't you have messed up somewhere...
    and
    change the file C:\d2ksetup.rc\d2ksetup.ini
    [Server]
    ScrSaver=0
    CacheSize=20
    License=1
    UseASRA=1
    DBDrive=E:\
    UseHDC=1
    HDCDVDCopy=1
    RFILE001=E:\
    RFILE002=E:\
    RFILE003=E:\
    RFILE004=E:\
    RFILE005=E:\
    RFILE006=E:\
    RFILE007=E:\
    RFILE008=E:\
    run sdswitch.exe from WIS DVD.
    Not my FIX, just trying to help.
  11. #56
    Hi..
    Yes i am sure i am messed up somewhere... the problem is i do not know where... I installed it into 3 different computer from the start... (new XP ) than made the partitions
    d: 6gig,recover, e: 20GIG WIS F:25GIG DAS
    Than put mr Zolookas prepare bat file
    gave the key for DAS and Xentry
    than start the DAS from G:stardiag/setup...
    After i finished that i put the xentry in there too from G:/stardiag/xentry-frame..... maybe that was the mistake?
    I do not have hotkey-local mashine-compact4
    I have:
    -STAR DIAGNOSE
    - BASICXP
    - cardreader
    - hms990 on
    - hotfix
    - multisetup
    - wis
    also in the star utilities starkey manager i only have the DAS and the Xentry... I do not have the WIS key application.....
    I do not know what i did wrong... must be something
    I tried to install the WIS from the sdswitch.... than i tried from ewa/sdinst/setup...
    wis version is 01/2011
    If anybody can help.... please do
    thanks again
  12. #57
    Hi mate. rename BASICXP to COMPACT4 (regedit) before start the install. work for me.
  13. #58
    DK Veteran milanista's Avatar
    Excuse me if this is not the right place to post this but I tried to install the 09.2011 update and I failed. I had successfully installed 07.2011 following the guide 2h (big THANKS to the team for providing it). I tried to update to 09.2011 and I have error from Partition Magic that there are only 7 MB free on the HDD which is a very strange error because on all drives there is plenty of free space. Anyway I tried to bypass the installation of Partition Magic and I ended up with Xentry and DAS deleted. After that I used guide 2h again and now my system is back and running again.
    It seems some fixes are required for 09.2011 so guys be careful!
  14. #59
    Feb 2009
    moon
    Quote Originally Posted by milanista View Post
    I read some respected and known user in other forum saying 9-2011 was a walk in the park similar to 7-2011.
    Why don?t you try fresh installation. maybe its because you are updating.
  15. #60
    Quote Originally Posted by selefkos View Post
    Here the Fix m8!!!
    How to start DASsim after fix apply?
    I'm trying to run simdas.exe but i get "no language defined!" message and it doesn't run.
    Best Regards
  16. The Following User Says Thank You to papalos_ For This Useful Post:
    dragonblack070 (16th November, 2014)
