Results 1 to 15 of 24
    Default DIAGBOX INSTALL ERROR : Error during installation of Lexia
    I install the diagbox 5.02 copy the patch and run it successfull, but when I activate it input custome code 1234567 number:12345678901234567890123456789011 profile:02FFFFFF, it start to activate but then eject a error window: Error during installation of Lexia. You have to recativate to restart the installation.
    What should I do??????
    morfej's Avatar
    Install it form DVD or mount the image with virtual drive software. I got exactly same error when I tied to install DB from folder.
  3. The Following User Says Thank You to morfej For This Useful Post:
    Rasmus (4th July, 2022)
    drakov's Avatar
    Aug 2008
    Or bad image
    Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
    Thank you, let me try it again.
    successed.
    DK Veteran scotcruz's Avatar
    Sep 2010
    S C O T L A N D
    Sorry to resurrect an old thread but I am trying to install Diagbox using a DVD but I keep getting "Inadequate space to install Daigbox" error.
    I have more than 70GB available so not the drive. What else could it be? Has anyone else experience this?
    I am installing it on Win XP
    Cheers
    drakov's Avatar
    Aug 2008
    Dont install from dvd, mount image the run setup;-)
    Sep 2010
    S C O T L A N D
    Brill mate... Never thought of that... Will try and let you know..
    Sent from my HTC Sensation Z710e using Tapatalk
  10. #9
    Sep 2010
    S C O T L A N D
    No luck, tried mounting the image to a virtual drive but still the sane error... Please help
  11. #10
    drakov's Avatar
    Aug 2008
    corrupt disc/image
  12. #11
    peko's Avatar
    which interface you use ? same as pps ?
  13. #12
    Slovakia
    Instaled Diagbox no problem. Now when I acces the car systems lets say BCM and want to try to go in to make changes it requires to make a phone call to a call center to obtain an access code. I use the original interface not china.
    With the old soft where there was Lexia and Peugeot Planet separated this works on the same car no problem for the BCM to change options no access code is needed.
    Any idea what is wrong or maybe I dont have the correct installation ???
    Soft is activated...
  14. #13
    drakov's Avatar
    Aug 2008
    bad activation method
  15. #14
    Slovakia
    Can you give me more info pls... I am telling you I used the tool to generate the activation code and it accepted. I can also work with the diagbox and see the details from the BCM just canot modify the parameters.
  16. #15
    Dec 2010
    dont forgot to disconnect your computer from internet when you use the diagbox
  17. The Following User Says Thank You to kar407 For This Useful Post:
    salahmanu (27th May, 2013)
