Page 80 of 149 FirstFirst ... 3070757677787980818283848590130 ... LastLast
Results 1,186 to 1,200 of 2223
  1. #1186
    Dec 2016
    yes green and blue plug i used pinout:
    Blue connector
    1 - +15
    23 - +30
    9, 24 - ground
    But i cannot see the milage i got "SAFE" in place where milage should be
    >>Genuine Winols, Swiftec, Ktag, Flex, x17<<
    >Diagnostic, Chiptuning, Dashbord<
  2. #1187
    alclot's Avatar
    Melee Island
    Hi mates,
    I´m looking for power up for Dodge Tourer (or joruney. I´m not sure) 2009.
    Thanks a lot
  3. #1188
    shuvarec's Avatar
    Aug 2018
    HI
    Help power up Toyota Highlander 2014-15-16
    TIA
  4. The Following User Says Thank You to shuvarec For This Useful Post:
    j81 (20th February, 2019)
  5. #1189
    lwood's Avatar
    city of angels
    Quote Originally Posted by shuvarec View Post
    HI
    TIA
    here you go.
    DON'T JUST SAY PRESS IT.....
  6. The Following 3 Users Say Thank You to lwood For This Useful Post:
    automotrizVIP (20th February, 2019), j81 (20th February, 2019), shuvarec (18th February, 2019)
  7. #1190
    world
    I need the power up pins for 2013 Renault Fluence cluster..
  8. #1191
    bidu20's Avatar
    Jun 2016
    Quote Originally Posted by gsmflasch View Post
    Stecker
    (Pin 1 - 12)
    2 +12V
    3 Kl. 31
    4
    5
    6
    7
    8
    9
    10
    11 Can Low
    12 Can High
    Stecker
    (Pin 13 - 24)
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    for powerup you need can message..
    Don't forget the magic button !
  9. The Following 2 Users Say Thank You to bidu20 For This Useful Post:
    alclot (21st February, 2019), gsmflasch (21st February, 2019)
  10. #1192
    tfourk's Avatar
    Jan 2016
    Fort Lauderdale, FL
    2019-02-22 08.46.19.jpg 2003 Porsche Carrera. If anyone has a power up, it would be greatly appreciated.
  11. #1193
    bidu20's Avatar
    Jun 2016
    Quote Originally Posted by tfourk View Post
    Stecker A grün
    (32 Pin)
    1 Kl. 31
    2 Kl. 30
    3 Kl. 15
    4 Kl. 15
    5 Spoiler ausfahren
    6 Kontrolllampe ausgefahren
    7 Spoiler ausfahren
    8
    9
    10
    11
    12 Alternator D+(Kl. 61)
    13 Motoröldruck
    14 CAN High
    15 CAN High
    16 Bremsverschleiss
    17 Kl. 31
    18 Kl. 15
    19 Standlicht
    20
    21 Spoiler Taster einfahren
    22 Spoiler eingefahren
    23 Spoiler einfahren
    24
    25
    26
    27
    28 Diagnose
    29 Zentralverriegelung Zu
    30 CAN Low
    31 CAN Low
    32 Bremsverschleiss
    Stecker B blau
    (32 Pin)
    1 Aussentemp.
    2 Motorölstand
    3 Sonnensensor
    4
    5 Druckgeber
    6
    7
    8
    9
    10
    11 Standlicht Dimmer
    12 Standlicht Dimmer Kl. 31
    13 Geschwindigkeits-
    signal
    14
    15
    16
    17 Aussentemp
    18 Motorölstand Kl. 31
    19 Sonnensensor
    20
    21 Sicherheitsgurt
    22 Handbremse
    23 Kühlmittelstand
    24 Waschwasserstand
    25 Airbag
    26 Blinker Links
    27 Blinker Rechts
    28 Fernlicht
    29 Bremsflüssigkeit-
    stand
    30
    31
    32
    Stecker grau (Pin 1-16)
    1 Tempostat aus
    2 Tempostat
    Abstand kleiner
    3 Cabrio Leuchte
    4 Tempostat setzen, beschleunigen
    5 Tiptronic 1
    6 Tiptronic 2
    7 Tiptronic 3
    8 Tiptronic 4
    9 Tiptronic 5
    10 Infosystem
    Eingang
    11 Infosystem Ausgang
    12 Gong
    13 Motorlaufsignal / Tagfahrlicht
    14 Tag/Nacht-Zustand
    15
    16
    Stecker grau (Pin 17-32)
    17 Tempostat Wiederaufnahme
    18 Überrollschutz
    19 Kupplungsschalter
    20 Tempostat grösser
    21 Bordcomputer Hebel vorne
    22 Bordcomputer Hebel unten
    23 Bordcomputer Hebel oben
    24 Bordcomputer Hebel hinten
    25 Bordcomputer Hebel innen
    26 Eingang Parkassistent
    27
    28
    29
    30
    31
    32
    here..
  12. The Following 2 Users Say Thank You to bidu20 For This Useful Post:
    alclot (22nd February, 2019), tfourk (22nd February, 2019)
  13. #1194
    tfourk's Avatar
    Jan 2016
    Fort Lauderdale, FL
    There is a language barrier here
  14. #1195
    bidu20's Avatar
    Jun 2016
    numbers are same in german :-)
  15. The Following User Says Thank You to bidu20 For This Useful Post:
    dashradio (22nd February, 2019)
  16. #1196
    tfourk's Avatar
    Jan 2016
    Fort Lauderdale, FL
    Quote Originally Posted by bidu20 View Post
    LOL Well what I meant to say is that I don't know which ones are ground and positive. Alternator I understand.. but the rest I'm kinda at a loss for words
  17. #1197
    bidu20's Avatar
    Jun 2016
    Contact Meaning Old terminal designition[1]
    Ignition system
    1 ignition coil, distributor, low voltage
    1a, 1b distributor with two separate circuits
    2 breaker points magneto ignition
    4 coil, distributor, high voltage
    4a, 4b distributor with two separate circuits, high voltage
    7 terminal on ballast resistor, to distributor
    15 battery+ from ignition switch 16
    15a from ballast resistor to coil and starter motor 16
    15e battery+ from ignition switch, also when starter motor runs
    Preheat (Diesel engines)
    15 preheat in +
    17 start
    19 preheat (glow)
    Starter
    45 starter relay 30f, 30h
    45a starter 1 output 30h, 30h I
    45b starter 2 output 30h II
    50 starter control
    50a starter control
    50b starter control 50
    50c starter control 50 II
    50d starter control 50b, 50k
    50e starter control 50a
    50f starter control 50
    50g starter control 50a
    50h starter control 50
    Battery
    15 battery+ through ignition switch 16, 54/15
    30 from battery+ direct 30/51
    30a from 2nd battery and 12/24 V relay
    31 return to battery- or direct to ground
    31a return to battery- 12/24 V relay
    31b return to battery- or ground through switch 85d
    31c return to battery- 12/24 V relay 31, 31a
    Electric motors
    32 return 31
    33 main terminal (swap of 32 and 33 is possible) 30
    33a limit
    33b field 54e
    33f 2. slow rpm
    33g 3. slow rpm
    33h 4. slow rpm
    33L rotation left 30L
    33R rotation right 30R
    Turn indicators
    49 flasher unit in 15, 15+, 15/54, +, +15
    49a flasher unit out, indicator switch in 54L, S, S4
    49b out 2. flasher circuit
    49c out 3. flasher circuit
    C 1st flasher indicator light K, K1, P
    C2 2nd flasher indicator light K1, K2, K3, K4
    C3 3rd flasher indicator light K3, K4
    L indicator lights left HL, L54, VL
    R indicator lights right HR, R54, VR
    L54 lights out, left SBL
    R54 lights out, right SBR
    AC generator
    51 DC at rectifiers
    51e as 51, with choke coil
    59 AC out, rectifier in, light switch 51, 51-, 51a
    59a charge, rotor out 59
    64 generator control light
    Generator, voltage regulator
    61 charge indicator (charge control light)
    B+ battery + 51, 51B+, B+30, B+51
    B- battery - 31B-
    D+ dynamo/alternator diode+
    D- dynamo/alternator diode-
    DF dynamo field
    DF1 dynamo field 1
    DF2 dynamo field 2
    U, V, W AC three phase terminals
    Lights
    54 brake lights
    54g lights 54
    55 fog light N
    56 spot light
    56a headlamp high beam and indicator light
    56b low beam F
    56d signal flash
    57 parking lights
    57a parking lights P
    57L parking lights left PL
    57R parking lights right PR
    58 licence plate lights, instrument panel
    58d panel light dimmer 58b
    58L parking light 58
    58R parking light 58
    Window wiper/washer
    53 wiper motor + in 1, 3, 54d, S
    53a limit stop + 54, +2
    53b limit stop field 3, 54e
    53c washer pump
    53e stop field 1, 2
    53i wiper motor with permanent magnet, third brush for high speed
    Acoustic warning
    71 beeper in H
    71a beeper out, low
    71b beeper out, high
    72 hazard lights switch
    85c hazard sound on
    Switches
    81 opener
    81a 1 out
    81b 2 out
    82 lock in
    82a 1st out
    82b 2nd out
    82z 1st in
    82y 2nd in
    83 multi position switch, in
    83a out position 1
    83b out position 2
    Relay
    85 relay coil - Important if relay coil has diode in parallel
    86 relay coil + Important if relay coil has diode in parallel
    Relay contacts
    87 common contact 30/51
    87a normally closed contact
    87b normally open contact
    88 common contact 2 30/51 (relay)
    88a normally closed contact 2
    88b normally open contact 2
    Additional
    52 signal from trailer
    54g magnetic valves for trailer brakes
    75 radio, cigarette lighter R
    77 door valves control
  18. The Following 4 Users Say Thank You to bidu20 For This Useful Post:
    alclot (26th February, 2019), dashradio (22nd February, 2019), skens (26th February, 2019), tfourk (22nd February, 2019)
  19. #1198
    Hello. I need pinout for this dash.
    Toyota Yaris - Year 2008
  20. #1199
    shuvarec's Avatar
    Aug 2018
    Help power up doge ram 1500 2014-18
    TIA
    If i help, don't forget to press thanks + rep button !!!
  21. #1200
    bidu20's Avatar
    Jun 2016
    Quote Originally Posted by InfoPerformance View Post
    Stecker
    (24 Pin)
    1 Kl. 30
    2 Kl. 30
    3
    4
    5
    6
    7
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24 Kl. 31
    here..
  22. The Following 4 Users Say Thank You to bidu20 For This Useful Post:
    alclot (5th March, 2019), InfoPerformance (5th March, 2019), pedrod2005 (27th February, 2020), rtbdiagnostic (29th May, 2019)
