alclot (25th November, 2018)
I needed the pinout of the dashboard mazda bt 50 2007. the temperature pointer does not move. I already put another dasboard also does not move. With the machine I can read the temperature in the ECU.
If I'm not mistaken it uses same cluster as from same year Ford ranger.
Attaching cluster wiring diagram for that year Ford Ranger.
As for a quick glance looks like pin # 10 is 12V and pin # 3 is GND.
Hope it helps. Good luck
alclot (25th November, 2018), Cbrcluster (14th April, 2020), cjawahir (25th November, 2018)
2011 - 2015 Toyota Sienna LE 3.5 93c66 (no difference in cluster) power up plus chip location.
Don't mind 0 miles and ugly soldering. This odo was fixed at least 5 times from my guessing...
VW SURAN / CROSSFOX / FOX 2010 - 2015 24C32
IF MY POST IS USEFULL PLEASE DONT FORGET CLICK ON REPUTATION AND THANKS
alclot (27th November, 2018)
Hi mates,
I have dash from Citroen C4 year 2009. Can I have power up here?
Thanks in advance
rokibar (28th November, 2018)
alclot (28th November, 2018)
Chrysler PT Cruiser
Need help to power up
Chupsy (4th December, 2018)
Stecker links grau
(26 Pin)1 Kl. 31 2 Kl. 31 3 Handbremslampe 4 Kl. 30 5 nicht belegt 6 nicht belegt 7 8 nicht belegt 9 Fahrertür offen 10 Ausgang Blinker links 11 Eingang Blinker links 12 Ausgang Blinker rechts 13 Eingang Blinker rechts 14 Kl. 15 15 16 17 nicht belegt 18 Fernlicht 19 20 Sitzgurt 21 Handbremse 22 Instrumentenbeleuchtung 23 Beifahrertür offen 24 Kofferraum offen 25 Programm VPM 26 PCI Bus
here mate.. what is the problem with your dash?
Don't forget the magic button !
Tumosan
İ need Power up(+12V -GND)
WhatsApp Image 2018-11-30 at 12.30.21 (1).jpg WhatsApp Image 2018-11-30 at 12.30.21.jpg
Need help to power up Suzuki motorcycle board inazuma 250cc
Thank you!
Piaggio Beverly 300 350 dashboard power up
Thanks + rep if helped
Hi mates,
Can I have power up for Citroen Nemo 2009 please?
Thanks in advance![]()
