Thread: RCD 300 Golf V
    Default RCD 300 Golf V
    Hi!
    Is it possible to power on RCD 300 on bench to test it?
    i put in 12V on pin 15 and ground to pin 12
    when i press power button radio only is blinking for 1 second.
    do i need can bus module to run? which was can do this?
    thx chris
    M1DJF's Avatar
    West Yorkshire
    Yes you can power this radio with out any problem the only thing I can think of is power to the unit there should be 2 x 12v supply to the unit inmost cases there is a diagram on the radio. As this radio does not look for Canbus.
    If you can't repair it, leave it as you found it, don't destroy it.
    i only can find one 12V
    guneymemo's Avatar
    Turkey
    rcd300 dont want code in the car only want code on the bench
    M1DJF's Avatar
    West Yorkshire
    from your diagram pin 15 and 16 +
    Quote Originally Posted by chriskross View Post
    the pin 16(safe) need 12 v
