is there a plugin for cccaminfo 1.3c
i've had it on a couple of images and shows the name of channels being viewed on cs studio.
is it available as a plugin and does anyone have it to upload.
cheers.
cheers.
it's ok. i got it......i need to work ou how to make it do what i want.
Cccam info V 1.3c for Dreambox 8000HD;800HD;500HD & +7025
Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
previous life dm800hd and 500c on cablescrew you nag3
i got that plugin installed now but not doing what i want.
@dctyper, yep mate on cs studio and also the webrowser with ip:16001 it tells you the name of the channel instead of the caid. which was nice.
it does so on the 4react image, the vix image and one i flashed this morning but no good arthur bk nemesis image.
its cool...if i can get it to work..........
@ davvo. thanks mate. i downloaded that via the plugins menu but not what i was hoping it would do
anyone know what we need to do to get cccam to display name of channels are being watched by client???
dont know why but mine shows channel on duo but not on dm800 using cs studio. you can copy paste that code into google it will tell you what they watching but why would you want to, if you share with someone then you are giving them permission no matter what they watch.
it just looks nicer on the eyes...thats all. instead of some numbers. not a major thing as i didn't know anout it but now i do.....its that curiosity thing more than anything else.![]()
you need to have cccam.channelinfo
# Example config to show channel names in webif instead of caid:ident:sid
0100:000065:00CA "Cyfra+ 13.0E AB Moteurs [S2]"
0100:000065:00CC "Cyfra+ 13.0E Chasse et P***9500;?che [S2]"
0100:000065:00CD "Cyfra+ 13.0E XXL [S2]"
0100:000065:00D7 "Cyfra+ 13.0E XXL PL [S2]"
0100:000065:00D9 "Cyfra+ 13.0E France 5 [S2]"
0100:000065:00DA "Cyfra+ 13.0E France ***9500;? [S2]"
0100:000065:01F7 "Cyfra+ 13.0E France 2 [S2]"
thanks mate...have you got that file...is it like an addon? how do i put it in my box?
I refuse to answer that question on the grounds that I don't know the answer. - Douglas Adams
i got cccam.channelinfo and cccam.providers both have file types as file.
where do they need to go?
cheers.
thanks. i just found it
and all working. simple when you know how.
thanks again bongindu.
just to complete the thread......if anyone else needs it. here are the files.
just extract and stick it in var/etc same place where your ccam.cfg file is.
