Results 1 to 3 of 3
    N/A
    Default How to force regeneration DPF in Crafter LT3
    How to do force regeneration of DPF in Crafter LT3?
    I have VCDS 11.2, i tried this manual from ROSS page but no joy :-(
    Particle Filter Emergency Regeneration
    Prerequisites:
    • Ignition ON
    • Engine ON (Idle)
    • Oil Temperature above 70 ?C (see MVB 007.2)
    • Particle Filter Load below 68g (see MVB 104.3)
      • If the Particle Filter Load is above 68g the Particle Filter needs to be replaced since the car may burn down when regenerating.
    • Engine Hood CLOSED
    • Parking Brake ENGAGED
    • Transmission in (P)ARK
    • Temperatures at the Exhaust System may rise up to 300 ?C!!!
    • No Fault Codes Stored
    • Power Consumers ON (Light, Seat Heating, Front/Rear Window Heater, Climate Control)
    The Regeneration may take up to 40 minutes, the engine speed automatically increases to about 1500 RPM.
    [Select]
    [01 - Engine]
    [Coding-II - 11]
    • Start Regeneration by Entering 10016.
    [Do It!]
    [Meas. Blocks - 08]
    Select all 3 Groups at once 100, 101 and 102
    [Go!]
    MVB 100.1: Engine Speed
    MVB 100.3: Regeneration Counter/Timer
    MVB 100.4: Regeneration Abort recognized (0 = No Abort/1 = Abort recognized)
    MVB 101.4: Regeneration Status (001 = Heating Up, 010 = Regeneration, 100 = Cooling Down)
    MVB 102.1: Temperature before Catalyst
    MVB 102.2: Temperature before Particle Filter
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    Any ideas?
    Usa
    N/A
    Quote Originally Posted by marinescuv View Post
    is it 3.0 tdi
    crafter 2.5 R4?
    I think 2.5l R5.
    Tomorrow i'm gonna test your solution.
    EDIT:
    Doesn't work :-(
