Page 6 of 11 FirstFirst 1234567891011 LastLast
Results 76 to 90 of 158
  1. #76
    Dec 2017
    Denver, Colorado
    The VAG Eeprom programmer 1.19g.rar link isn't working. I was able to download from the K+CAN VAG COMMANDER 2.5.rar link but for some reason the VAG Eeprom programmer 1.19g.rar link sends me to the log in screen even though I'm already logged in. Is there another link for the software? Thank you.
  2. The Following User Says Thank You to jmorris1140 For This Useful Post:
    telescui (21st December, 2017)
  3. #77
    Dec 2014
    PL
    Quote Originally Posted by jmorris1140 View Post
    Hi.
    Have you read post No. 75. You tried to download ? If not, try it.
  4. The Following User Says Thank You to Mario6 For This Useful Post:
    telescui (26th December, 2017)
  5. #78
    Jan 2018
    Quote Originally Posted by Mario6 View Post
    Hi.
    for me the same. I tried the link from post 75 i was only able to download the commander not the eeprom programmer.
  6. #79
    Dec 2014
    PL
    Quote Originally Posted by dede2k View Post
    Yes you are right . There is no difference in the possibilities of Vag commander 1.4 and 2.5. As I used 1.4, sometimes my laptop reported a bug. Using 2.5, I did not notice it.
  7. The Following User Says Thank You to Mario6 For This Useful Post:
    viking6791 (14th January, 2018)
  8. #80
    Oct 2018
    hi this is a old message but can someone help me get hold of this programme
  9. #81
    Oct 2018
    its all cool i have it now now just trying to work out needle sweep
  10. #82
    Dec 2016
    UK - South East
    Quote Originally Posted by criesto View Post
    For reading and writing eeprom file use vag commander or vag eeprom programmer, but for needle sweep I think you'd better use Dash Dump Edit.
  11. #83
    Dec 2014
    PL
    Hi.
    Here is DashDumpEDIT.
    https://www.drive2.ru/l/471768829593126099/
    To re-upload the converted eeprom you need to use Vag K commander 1.4 / 2.5/ 3.6 ,Vageepromprogrammer 1.19g or other.
  12. The Following 2 Users Say Thank You to Mario6 For This Useful Post:
    castin (26th December, 2018), YASS59 (7th March, 2021)
  13. #84
    Nov 2018
    I hope the download works for my car. I need to tsts it
  14. #85
    Dec 2018
    help pls, i have already downloader the VAG Eeprom programmer 1.19g.rar , from here, and it opens, i choose the usb port, and next i try to read something and says no ecu found, but with vcds 17.8 it works fine, by usb too, i have already try so much things but now i dont have more ideas.
    Sorry for my english.
  15. #86
    Dec 2014
    PL
    Write what car, year of production and what controller you want to connect with.
    With the vag eepromprogrammer 1.19g, you can read eprom, pin immo and change the odometer in the VDO cluster.(to 2004my) I have never been able to connect with the ECU motor. I Connected with the airbag controller in the VW Passat B5 2000 my 6Q ..... I also managed to erase the errors in ABS. If you can not connect via USB, try using COM PORT on which your VAG KKL is. But only comport 1 or 2.
  16. #87
    Dec 2018
    The car is a Audi a3 8l 2001 1.9tdi 130cv, i have a cable vag k+can (hex+can), and i am trying get the pin immo, i already try use the Com Port that vcds driver create, but is the same, i tryed to all the controllers to, and read fault codes of the engine and nothing
  17. #88
    Dec 2018
    Corretion, the COM PORT that creats is com3 and in eepromprogrammer only have the com1 and com2
  18. #89
    Dec 2014
    PL
    Actually, I do not really understand what cable you have VCDS HEX + CAN or VAG K CAN COMMANDER 1.4 / 2.5 / 3.6.
    -vag eepromprogrammer 1.19g works with VAG KKL device and vag k commander device.
    -vag k can commander 1.4 / 2.5 / 3.6 with dedicated device vag k can commander (and vag kkl 1.4/2.5).
    -VCDS Hex+Can- only VCDS Software
    If you have an Audi A3 from 2001 with 1.9 tdi engine then you have immo III. Pin immo is the same in instrument cluster and ECM EDC 15. Pin immo can be read using the VAG KKL interface or the vag k can commander interface. The VCDS interface does not read the pin immo .
  19. #90
    kiszka's Avatar
    Here you have it.
    Both programs work with VAG KKL
    ATTENTION
    this file has a virus K+CAN VAG COMMANDER 2.5.rar
    Win32 / sality.nba https://blog.satinfo.es/tag/win32sality-nba/
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
