Page 1 of 7 123456 ... LastLast
Results 1 to 15 of 99
    Dec 2010
    United Kingdom
    Question Vag-com 409.1.......... Activation
    Does anyone have solution to activate vagcom 409.1?
    Member ogo777's Avatar
    croatia, zagreb
    yep
    find here, vag com 409.1 usb
    this sw is full reg
    work excellent
    or, wait
    i post it here, today
  3. The Following User Says Thank You to ogo777 For This Useful Post:
    Mihaescu (12th February, 2023)
    miha99's Avatar
    EU
    Maybe with this.
  5. The Following 22 Users Say Thank You to miha99 For This Useful Post:
    alex64 (23rd December, 2022), CamW (8th November, 2023), Col19 (17th November, 2019), erecekmte (19th January, 2022), flashme (9th September, 2021), juandizee123 (4th March, 2023), kroy0402 (20th April, 2020), lautaruno1 (18th October, 2022), meandyoujane (1st May, 2020), Mihaescu (12th February, 2023), Mulik5 (15th April, 2023), muratozyegen (30th December, 2017), nobbny (28th July, 2022), Papiti56 (9th August, 2021), pedrag2 (20th December, 2024), psabad (12th September, 2022), qeweacss (12th February, 2023), servicem (30th April, 2020), sirdaniel (26th February, 2018), tamer1024 (22nd January, 2020)
  6. #4
    croatia, zagreb
    here is
    vag com 409.1
  7. The Following 30 Users Say Thank You to ogo777 For This Useful Post:
    Aivariuxass (3rd February, 2024), alex64 (23rd December, 2022), amstel7 (28th October, 2022), aozdag (24th January, 2025), armin5000 (16th May, 2023), Arnie Moe (6th May, 2022), Col19 (17th November, 2019), ecufix (30th January, 2021), flashme (9th September, 2021), gardusis (14th May, 2023), glockandor (27th November, 2022), Heronix (14th June, 2018), hillan (13th June, 2018), jmac200t (10th October, 2021), juandizee123 (4th March, 2023), kroy0402 (20th April, 2020), lautaruno1 (18th October, 2022), lowdwnsteve (22nd March, 2021), meandyoujane (1st May, 2020), Mulik5 (15th April, 2023), muratozyegen (30th December, 2017), Papiti56 (9th August, 2021), psabad (12th September, 2022), seal777 (18th August, 2022), servicem (30th April, 2020), sirdaniel (26th February, 2018), svedukas (8th May, 2017), tamer1024 (22nd January, 2020), zedan (17th December, 2019)
  8. #5
    Ok mate , thanks for the SW, but I need version with RS-232 ( serial Com-port 1 ) , not USB .
    Some Help ?
    Thanks for all M8.
  9. #6
    May 2017
    Is there still someone that has the full version of Vagcom 409.1??
  10. #7
    Spain
    Use VCDS Lite, are better, and works with KKL interface.
  11. #8
    May 2017
    Maybe someone happen to have activated VCDS lite? Right now I only have trial version, with one dtc reading per module...
  12. #9
    Jan 2019
    Ill try this . Thanks!
  13. #10
    Jan 2019
    anyone still using vagcom 409.1?
  14. #11
    Dec 2014
    PL
    You better use this. (VCD$ Lite 1.2)
    "THANK YOU"
  15. The Following 68 Users Say Thank You to Mario6 For This Useful Post:
    admteam (3rd December, 2022), ahmed_mo (4th April, 2021), andrea2107 (3rd January, 2025), andyman (29th May, 2023), aozdag (24th January, 2025), b00st1n (17th November, 2024), bendetest (5th April, 2024), BrutusMaximux (21st April, 2023), CamW (8th November, 2023), Col19 (17th November, 2019), CroPirat (23rd July, 2022), davidkeee (15th July, 2024), DilleDalle (9th November, 2024), Dolfke (7th January, 2025), DutchGuyMikey (3rd January, 2025), DX AUTO (15th November, 2024), eduaro (5th July, 2022), eliah (4th April, 2023), ELVIS15 (19th June, 2023), Fahad1973 (16th October, 2021), FATAYMEN (22nd June, 2022), Feche (1st February, 2025), fertag (3rd July, 2023), flashme (9th September, 2021), FoundTheCable69 (20th September, 2024), Frechi73 (14th September, 2023), GajoOptimus (18th April, 2022), HacKage (23rd April, 2023), hrabo72 (18th February, 2023), Ivasoad (17th October, 2019), juandizee123 (4th March, 2023), Kaliause (18th February, 2023), KMPerformance (9th April, 2022), Kokot1 (18th April, 2025), korn (23rd April, 2021), kroy0402 (20th April, 2020), latoo (7th May, 2020), lautaruno1 (18th October, 2022), LeCrewVis (23rd March, 2025), lesli (26th September, 2019), M8V22 (21st July, 2024), marinos (19th March, 2025), Markhodges78 (3rd August, 2021), meandyoujane (1st May, 2020), mijirap362 (20th April, 2024), mtkc22 (16th July, 2024), Mulik5 (15th April, 2023), nanou2 (20th March, 2024), Nesthxc (17th January, 2024), nikolakla (23rd July, 2019), oagarashi (11th November, 2024), Omar911 (26th February, 2025), rickyxlz (26th April, 2025), sdosal (18th November, 2022), servicem (30th April, 2020), sheffy (11th November, 2024), Sigan2 (30th May, 2021), SuperTaranta (15th April, 2023), tamer1024 (22nd January, 2020), welshkid (2nd June, 2024), xiderke (11th December, 2024)
  16. #12
    Apr 2019
    Quote Originally Posted by Mario6 View Post
    So it installs but is not activated?
    I just need to check my VW timing but dont have the money for the software.
    The timing belt kit broke my piggy bank.
  17. #13
    Dec 2014
    PL
    This vcds lite 1.2 is activated. It serves cars until 2004 y without "can"
    After installing the vag kkl cable drivers, you must set COM PORT. It can be only 1,2,3 or 4. You set the same COM port in vcds lite 1.2 (OPTIONS) as in the device manager. Then connect the cable to the car and computer and do the test in the "OBD II" tab. Then again OPTIONS cable test. LIcence in "ABOUT" should be "green". Try.
    Or buy yourself a vcd$ hex-can for older (2004 y) and newer (after 2004) cars of the VAG group.
    https://pl.aliexpress.com/premium/vc...d=0&isViewCP=y
  18. #14
    Dec 2016
    Hello, I have this serios problem with VCDSlite 1.0. Maybe I must reinstal windows. I using on old pc and works 100%. After instal on new pc I have N/A issue problem in 2-3-4 blocks, but others functions works. But I unable logs others blocks.
    Old and new PC its W7 64bit SP1. difference its only cpu Haswell and Skylake. Maybe windws version updates are different.
    I try reinstaling, direct copy, deleting all vcds and ross-tech elements by regedit. I dont now, in fact is very mistake problem. here its my video.- In video I first show work on shareware with normal 2-3-4 block, and after minute, I showing issue by using loader with N/A blocks.
    https://youtu.be/9lonwYpf7AE
    Thanks for any help.
  19. The Following User Says Thank You to mirrco For This Useful Post:
  20. #15
    Dec 2014
    PL
    Install and test vcds lite 1.2 (post #11). Works on win xp, win 7, win 8.1 without problems.
  21. The Following 2 Users Say Thank You to Mario6 For This Useful Post:
    Kaliause (18th February, 2023), marinos (19th March, 2025)
