    Nov 2010
    Default lucas epic diesel pump calibration fiat palio
    hi friends i have fiat palio 1.9 d lucas pump fault code injection pump rotor error do anyone have the solutoin to calibrate this pump . your help grateful to me thanks
    Usa
    i have trouble code p0252 in fiat doblo with lucas epic pump,what to do ? need rewrite eeprom?
    Quote Originally Posted by nasir View Post
    a callus 0.25mm at the rear of the pump is returned in the order
    une cal de 0.25mm ? l'arri?re de la pompe est tout rentre dans l ordre
    Bratislava,Slovakia
    0.25mm......ok....it is.
    Error returned P0252.
    How to repair?
    hello everyone
    give more detailed, so that I can help you
    pandokrator's Avatar
    Oct 2008
    Eu.Gr
    hi,
    is old thread but i have now a second doblo 1.9D with Lucas pump
    some times (with moving wires from pump to ecu) P0252 code deleted and car run well ,
    but more times take this code and engine increased and reduced rpms :-(
    is that a wiring prob ?
    don't think is a fuel pump or position sensor because have fitted a new one.
    the only help i have found on net is this
    any wiring diagram or solution can be hopeful.
    thanx in advance.
