Results 1 to 10 of 10
    Default 7-digit PIN/SKC (Secret Key Code)
    pls i just bought super vag k can plus . i dont know read skc with this tool pls who can help me out
    Nov 2010
    for which car you are reading the password just connect your vag tool & go to function pin reading if your tool communicate with your car it will give the pin code if you get 4 digit pin just add zero before first digit .
    am doing passat 2002 i need 7-Digit SKCs pls how i get it or dont i need it. please how i convert 4 digit pin to 7 pin
    Mar 2011
    Chana Liaoning
    4 digit pin is enough
    Nov 2010
    hello friend if you get 7 digit code post the code here someone will convert to 4 digit .
    Germany
    Quote Originally Posted by chunliu View Post
    hi ,
    hier
  7. The Following 5 Users Say Thank You to 16eddi67 For This Useful Post:
    danijelggg (16th December, 2019), lounadak (12th March, 2022), myma7up (12th October, 2022), Rebello Brian (4th September, 2020), uras (15th September, 2019)
    my good friends i have the four pin what am doing is ecu changing please help with the procedure ross tech i need the 7pin
    Default please i need assistance
    please any body who can help me with the immo 3 vag programming
    i want to know can the ecu be programmed with just the 4 pin code
    i have the 4 pin code but ross tech is talking about 7skc pin code
    how can i convert the 4 pin to 7 pin
  10. #9
    DK Veteran marte690's Avatar
    Italy
  11. The Following User Says Thank You to marte690 For This Useful Post:
  12. #10
    pls sir
    how do i contact the retrieved by the Dealer for the 7pin code pls help me out
