    Dec 2018
    Espaņa
    can someone pass me the ori file of these two ecus?
    4b0906018AA
    0261206449
    4b0906018DH
    0261207928
  2. #16517
    calibracbr's Avatar
    Aug 2015
    Moon
    Quote Originally Posted by robercs97 View Post
    4b0906018AA
    0261206449
    4b0906018DH
    0261207928
    I hope it helps you
  3. #16518
    Jun 2020
    Quote Originally Posted by Davide1312 View Post
    HO BISOGNO DI UN FILE DI ACCORDATURA N SW 1037375951
    Here is your file,
    Best regards
  4. #16519
    Dec 2021
    Hi guys,
    i hope you are doing well. i am looking for a damos of golf 6 1.6 TDI PCR 2.1 to make EGR OFF DTC OFF. anybody can help here please.?
    thanks in advance.
    BR
  5. #16520
    Feb 2022
    Quote Originally Posted by dawco998 View Post
    Risky map you have there for stock avn.
    Catch safe one, max power for stock and hardly no smoke.
    Leave thanks
    Thank You for Your interest. Can't get a little more on stock setup? The car drives only a bit better than on the oryginal map.
    I made another one, based on a ready map for this 1.9 TDI AVB engine:
  6. #16521
    Feb 2022
    Hello! Seat Altea 1.9 pdtdi bkc, should be for manual transmission car, 40 hp plus, EGR off, warm start trouble. R4 1.9L EDC G210SG 7000. 03G906016HB, 0050071, vin: vszzz5pz6r022575. Thank you very much! ressmisi@gmail.com
  7. #16522
    skens's Avatar
    Zagreb,Croatia
    hi
    Please tune Skoda_Octavia_2017_1.6_TDI_CR_EU6_115_hp_Delphi_DC M6.2V
    mechanical transmission
    regards
    Please dear members push the button thanks and reputation button(stars)
    do you need help? fill it in !!!
    Model:
    Motor capacity:
    Diesel/Gasoline:
    Production year:
    ECU type and number:
    Memories :
    https://www.digital-kaos.co.uk/forum...63#post1660863
  8. #16523
    Dec 2018
    Espaņa
    hello, could you make me stage 1 +inmo off
    4b0906018DH
    0261207928
  9. #16524
    Oct 2019
    I'm need to STAGE1 and EGR OFF
    Skoda Octavia VRS 2.0tdi 170hp
    Siemens ppd1.2
    HW 03G906018EB
    SW SN100K5400000
    Greetings to all helpful and thank you for your help
  10. #16525
    Baddog84's Avatar
    Sep 2012
    Germany
    Quote Originally Posted by Umpapa View Post
    Siemens ppd1.2
    HW 03G906018EB
    SW SN100K5400000
    here is your file
    chks by tool
    WinOLS 5, FGtech, Piasini, Powergate M, Byteshooter, OptiCan Dual II, EVC BDM, VCDS, BeeProg+,Ktag, Kess V3, Autotuner, Bflash
    Fileservice
    no thanks no pass
  11. The Following User Says Thank You to Baddog84 For This Useful Post:
    Umpapa (20th February, 2022)
  12. #16526
    Jun 2020
    Quote Originally Posted by andrewgt View Post
    You can use at your own risk, car will smoke cause of turbo limitations, high torque will destroy stock cluch pretty fast and high EGT will make nothing good to your car aswell.
    You didnt touch boost limitation map so your turbo will blow 2050mbar so check into it. i suggest increasing it to 2250mbar (2300mbar max pressure for this turbo)
  13. The Following User Says Thank You to dawco998 For This Useful Post:
    andrewgt (21st February, 2022)
  14. #16527
    Jan 2022
    Germany
    Quote Originally Posted by gamerunner09 View Post
    Hello need a Stage1 for a Golf6 2008 160HP 1.4 tsi CAVD is this Posible ?
    Nothing ?
    Its a MED17.5.5
  15. #16528
    Feb 2022
    Witam potrzebuję Remap
  16. #16529
    skodaBG's Avatar
    Feb 2022
    Default BMW E91 330d 227 hp stage 1 + DPF & EGR OFF possible
    Hello all can someone help me with Stage 1 and dpf & egr for this car thank you
    Bmw Ecu Type : BOSCH EDC16CP35/C (BMW)
    Bmw Hardware ID : 07808222
    Bmw Software ID : 07793496
    Bosch Hardware Number : 0281013500
    Bosch Software Number : 1037387658
    Programming Date : 19.02.2007
    BMW Kline Fast Mode
    Read methos mpps v18
  17. #16530
    somewhere around here
    Default Tprot
    Hi all,
    Could someone be kind and help unlocking this file and making this EDC17C08 Kia ECU bootmode read suitable for writing via obd?
    Thank you
