Results 1 to 9 of 9
    Default nissan almera pulse
    53 reg, 1.5l, lost the keys so programmed 1 using nissan consult ,will start but everytime the ign is turned off for a few seconds, will not start again and key light flashes until i go back into system and program key again, this happens everytime. nissan consult says new key is programmed and car will start evertime if i start constantly, but when i leave a few seconds key light on dash flashes red and it will not start again. i do not have remote key with car just a transponder key, could this be the problem. thanks
    Liteace's Avatar
    Mar 2009
    On a rock
    Its not like some of the Ren's is it where you have to lock and unlck the doors before it will start
    Ashraf6119's Avatar
    Nov 2009
    UK
    Are you sure you have used the right Transponder Chip as when a wrong Transponder Chip is used that's how it does.............
    Also check the connections at the Key Reader Coil for loss connections..........
    Hope this helps................
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
    the transponder come directly from nissan ,it was a id46 for that vehicle. i had to take off immo box located up above the clutch pedal to get pin access code, as this car was on the change in that year. thanks for your replys guys, do you think they got it wrong on the transponder side. thanks
    could someone double check this is the correct transponder i have been supplied, id46. the car is a nissan almera pulse 1497cc petrol, registered 28/11/2003. vin number sjnfaan16u0457011. just need to no if i have been supplied correct transponder. thanks
    Ashraf6119's Avatar
    Nov 2009
    UK
    Some Almera from 2002 to 2005 use Silca T14, ID46..........and Some Almera from 2000 to 2003 use T13, 4D 60..........
    So, it could be yours is T13, 4D 60
    Thanks Ash
    Aug 2009
    Hi, radiosolutions !
    Nissan Consult can't programming key on NATS 5.0. This is manual procedure: after entering PIN code NATS light goes off ; turn ignition ON for ~5 sec ; turn ignition OFF for ~5 sec ; 1st key is programmed now, if you have other keys repeat previous 2 steps ; after programming all keys START the car with already programmed key. Turn ignition OFF and when NATS light comes flash, try to start with programmed keys.
    ashraf was spot on it was wrong transponder, originally they gave me the 4d60 chip, it was suppose to be a ID46. THANKS FOR ALL THE HELP
    Ashraf6119's Avatar
    Nov 2009
    UK
    I am glad you got sorted
    Good job mate..........
    Thanks Ash
