Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 62
  1. #31
    Quote Originally Posted by integlikewhoa View Post
    OK been a few weeks, but I got that message now and got shut down. Time to find away around this!
    WELL I HAD A FEW FILES BLOCKED ANSD IT WAS WORKING GREAT BUT I CAME IN THIS AM AND IT SAYS SAME THING AGAIN...I ghuess theres more to it then just the toekn file and one other od file. i had to open one of them not sure as it used the same file to go out and look for parts with manager soim gonna have to look at it close. i wish there was a program that would watch the pc and take not of any change to any file, henc when this file whatever one in mitchell is rewritten buy this check it would tell me what to block or what to rewrtite to make it lagit...the russians have had this thing going for months as i paid for it when it first cam,e out. i asked them whats up and i get have no idea never heard of it. thats where my suport stopped....guess ill have to reinstall. i know its with the repair key only the esitmator key is legit. i wish i knew where those files were stored by mitchell in what ini or what files as to make sure it cant be writeen to. any ideas, anyone?
  2. The Following User Says Thank You to uhaulkid For This Useful Post:
    subhanjaved (25th February, 2025)
  3. #32
    now we need 2012 crap already with estimator
  4. #33
    Oct 2010
    Default 346LSX Math problem pdf
    the first word in the question is 16 second word is + third word is 12 16+12=28
  5. #34
    Jan 2012
    These are 1Q disks. Please correct the Title of the post
  6. #35
    Dec 2010
    jordan
    I have downloaded this and then solved the math problem but it gives me an error in the picture
    Any solution ?
  7. #36
    Default system date error
    Try running OD5 as admin. Worked for me been 2 weeks and no error. Also blocked mitchell token and od5 no problem
    Edit.. spioke too soon just poped up with system time wrong
  8. #37
    Default thanks
    thank you, i have been search the web for this
  9. #38
    Newbie rdh1958's Avatar
    Quote Originally Posted by aymanmomani View Post
    Any solution ?
    I have the same problem. Anyone conquer this yet????
  10. #39
    California USA
    Don't worry even if you get past the install, in 1-3 weeks it gets shut down due to another software activation problem.
  11. #40
    I was uner the impression this was alive & well . I will keep using my old program.
    I will wait for the powers that be......to get it working for you & me.
  12. #41
    Member zorba anton's Avatar
    Buffalo NY USA
    Default mitchell ondemand5 v5.8.2.35 fix
    Most users find upgrading from version 5.0 to 5.1 of OnDemand5 to be a smooth and simple process. However, due to the complexity of the many operating systems and platforms now supported by the program, some upgrade issues have been reported in the field.
    If you are experiencing difficulty with your upgrade, please read the information below before calling technical support:
    1. Issue: Autorun must be on when 5.1 installs the .exe or the program does not look for OD5. This results in program conflicts since OD5 and OD5.1 were not designed to co-exist on the same system.
    DO NOT DISABLE THE AUTORUN FEATURE. If you have disabled the autorun feature and run setup.exe, the version checking may not ever take place and the upgrade of the OD5.0 to OD5.1 software process may not be successful.
    Workaround: Run StrtDsc2.exe from the Installation CD instead of Setup.exe. If the version on the machine and in the autorun.inf files does not match, a dialog is presented with the following message: "A previous version of OnDemand5 exists on your system. Do you wish to update now?"
    Click OK and you should be taken through the complete upgrade/ installation process.
    2. Popup windows options should be disabled at installation time.
    This is a software update/installation process. Therefore, program specific files, registry entries and/or system files and resources will get updated. So, Before you begin the OD5.1 installation process, ALL OPEN PROGRAMS MUST BE CLOSED ON YOUR PC INCLUDING OD5.0, ANY OTHER APPLICATIONS RUNNING IN THE BACKGROUND, ANTI VIRUS SOFTWARE, ETC. This is good practice for any software installation or upgrade.
    3. OD5 uninstall issues cause conflicts with the new OD5.1 installation process.
    The recommended way to uninstall OD5.0 is to use Add/Remove programs from Control Panel OR use Uninstall OnDemand5 from the program group. If neither of the above processes were successful, you can manually delete OnDemand5.0 provided that the following folders, files and registry entries are deleted before installing OD5.1:
    1. Delete the \Mitchell 1\ondemand5 folder.
    2. Delete the OD5.INI file located in \WINDOWS or \WINNT folder.
    3. Delete folder 5F7DFA-27B3-4E06-BCDE-B371424C0032 located under program files\installshield installation information.
    4. Delete Registry Entry: Hkey_Local_Machine\Software\MRIC\OnDemand5 folder.
    You should now be able to successfully install OnDemand5.
    http://www.mitchellsupport.com/FAQ/faqdocs/51_upgradeissues.asp
  13. #42
    Default Mitchell_On Demand
    How to use Disk v5.8.2 with V5.8.1.9 work only for Windows XP
    1. Copy folder Repair1_11_2A\ODM\idexes to folder
    C:\Mitchell1\OnDemand5\Shared\ODM
    2. Edit lines in file C:\Mitchell1\OnDemand5\Shared\shared.ini:
    SequenceNumber=??? to SequenceNumber=137
    DiscsInSet=?? to DiscsInSet=13
    BeginYear=19?? to BeginYear=1983
    EndYear=20?? to EndYear=2011
    SilkScreenID=5DVD??- ?? to SilkScreenID=5DVD11-2A
    SilkScreenID=5DVD??- ?? to SilkScreenID=5DVD11-2M
    3. Edit file c:\windows\OD5.ini with data path
  14. #43
    Buffalo NY USA
    Default Mitchell OnDemand Repair + Estimator 1Q 2011 | 78.46 GB
    Removed Dead Links
  15. #44
    Buffalo NY USA
  16. #45
    Buffalo NY USA
    Default MOD Installation instructions:
    1 - disconnect from the internet, the computer during the installation and activation; install and run
    1 - put a check mark in the Repair and Estimator and click Next
    2 - You should see a window with information about what the program could not connect to the internet to activate. If it does not appear, so you do not turn off the computer from the Internet. Click Continue.
    3 - From the dialog box, write down or remember two 5-digit numbers. This is a Computer ID number.
    4 - run a-key generator "KeyGenOnDemandQ32011.exe"; enter the Computer ID; solve simple math problem and enter the answer in the form of numbers. "Russian CAPTCHA" was made in order to restrict access to key generator only for Russian-speaking Internet users; click the Generate button.
    5 - Do Not copy/paste serial keys from the generator to activate, you MUST type in each set of four numbers six places for total of 24 numbers.
    You may not see all six places, just keep typing in all numbers. If successful, the Validate serial will be seen. Do this for both the Repair and the Estimator serials.
    Save these serials and validate numbers to a text file and save. Then click Next.
    6 - specify the path to date repair disk. Can be to an older version.
    Help with the MOD Math Problem
    It changes every time you open it.
    (example:16 + 19 = 35 your answer is 35)
    This will help Translate Numbers on MOD Generator.
    Keep Closing and Reopen the KeyGen until you get easy Russian Language to match below.
    Put the numbers together to add, subtract, etc., until you get the right code.
    Save and Open this image file to your machine to see all Russian Words and Numbers
    1 a'deen
    2 dva
    3 tri
    4 chetyre
    5 pyat'
    6 shest
    7 sem'
    8 vosem'
    9 devyat'
    10 'desyat'
    11 o'dinnatdsat'
    12 dve'nadtsat
    13 tri'nadsat'
    14 che'tyrnadsat'
    15 pyat'nadtsat'
    16 shet'nadtsat'
    17 sem'nadtsat'
    18 vosem'nadtsat'
    19 devyat'nadtsat'
    20 d'vadtsat'
    Last edited by zorba anton; 12th April, 2012 at 05:03 PM. Reason: Added image file
