Results 1 to 10 of 10
    3in1san's Avatar
    in the middle of europe
    Default Becker Indianapolis
    Can somebody help me generate cod to:
    Becker Indianapolis
    BE 7922
    45001041
    radio has 7-presets
    I be thankful
    try code 61131
    smoggy's Avatar
    Apr 2009
    UK North East
    try.....61132
    3in1san's Avatar
    I tryed both codes, both wrong
    61132 - genertated from becker 6-preseds calc
    61131 - becker 8-prededs generate 61138 becuse this model dont have 8, we take the next digits, which is possible to insert -> 1.
    also i tyied all codes 61131 -> 61137 and nothing
    I will probably have to see in this tiny eeprom
    If I see nothing i post dump.
    thanks very much for the help
    smoggy's Avatar
    Apr 2009
    UK North East
    of all the posts I've seen if it has 4 presets its the 4 preset calc all others regardless of how many have used the 6 preset calc
    maybe someone has changed the dump in the past
    HI,
    I have 2 indianapolis on the bench with working codes
    If I calculate your code in the same way your code is 61132
    looks kike itsbeen swapped
    spain
    you just give me serial number has 15 digits
    I just give you the code
    Argento7's Avatar
    Costa Rica
    Cant decode by serial... somebody has changed.
    __==41 72 67 65 6E 74 6F 37==__
    Taras+'s Avatar
    Bonbaden
    Quote Originally Posted by Argento7 View Post
    Cool work !
    3in1san's Avatar
    I read eeprom from this radio and dump is from this radio, becuse serial numer mach.
    Much to my surprise code is 61132 i try to put and not working (???).
    I put all BB BB BB i code field and code 11111 work.
    Very strange....
    I thank you all for your time.
