I need help in programming a 2007 Toyota Fortuner 2.7VVTi, can anyone help me out ?.
Hi mate ,can you show you remote.
Just like picture but it has 3 Button not 4.
These remote cannot program by programmer, only used mannaul programming
This for thailand model.Maybe can,just try but you need accurate follow the process and the time.Good luck
Make sure all doors are close
1)insert key into ignition
2)wait for 5 seconds
3)turn the ignition key from off to on 5 times (stop at on position)
note that the security light lights up in the 5th times
4)open & close the driver door
5)off the ignition key
6)open driver & on the ignition
7)close driver door& off ignition (do not pull out key)
8)press lock & unlock buttons on key together once & than press lock again (Central Lock Lock & unlock once means programming successful, if central lock lock & unlock twice means programming fail , try again)
I will give this a try and report.
I did get somethig very colse to this from the local dealer but I was unable to get it working.
Between your instruction part 5 and 6 they said the locks should cycle and it did not so I did not go to the other steps, also they did not mention the Secuirty Light up at the end of part 3
Customer will get back to me in a few days so I will keep you posted.
Thanks again
I think the battery of the remote also important.The manual programming need stronger battery(car and remote)
I finally tried it today and for some strange reason no matter what I did I could not get it to go to program MODE using the new REMOTE.
THe GOOD news is when I tried it with one of the original remote with only 2 of 3 button working it WENT into programming MODE and at that time I was able to get the new Remote programed.
The instructions are GOOD and that secuirty light only came on only with the working remote after the 5 key on key off.
THANKS AGAIN.
