    Default I need read eeprom from AUDI NAVIGATION RNSD
    hello, I need read the eeprom from one audi navi rnsd unit, but not can locate the 24c32 chip in the mainboard, can any post a photo from the pcb with the eeprom chip?
    can decode with normal blaupunkt decode software?
    regards
    Member Copax's Avatar
    Transylvania
    1. We need more info about your unit (model, manufacturer, serial numbers, etc). A picture of the label would be a good alternative.
    2. What do you mean by normal blaupunkt decode software?
    PS
    The code for VW navi units(almost) is in FIS module, not in EEPROM
    hello
    the unit is from A8 D2 car
    4D0 035 192 D
    UNIT IS DX
    I have a xprog-m , can read the fis with xprog?
    have any diagram to try read
    what software need for decode the dump from the fis?
    regards
    Transylvania
    Still need info.
    The Blaupunkt part number for example
    Something like this : 7 612 001 370
    You have in atach something usefull.
    Read the FIS and put here the dump.
    You can do it with xprog-m, just connect the SCL, SDA and GROUND
    It is important that you have no power connections made to your target unit other than those required by
    your programmer.
    Argento7's Avatar
    Costa Rica
    Quote Originally Posted by Copax View Post
    Still need info.
    your programmer.
    Maybe offtopic, but have you some schema or diagram to build this tool?
    Thanks Copax
    __==41 72 67 65 6E 74 6F 37==__
    Transylvania
    I don't have the schematic, sorry Argento7.
