Results 1 to 7 of 7
    Edit Value 49?15'30."N 124?35'40."W 100M above datum
    Default Panasonic CF 52 SATA driver
    Hello Folks
    I have a Panasonic CF-52gcmbxam machine that has Win7 loaded.
    I Want to install XP pro on the machine from a new disc.
    My problem is trying to get the windows setup disc to see the Hard disc.
    I have tried some sata drivers from Panny :
    https://panasonic.ca/english/custome...areResults.asp
    Or
    Official Support Download Center of the Drivers, Manuals and FAQs | TOUGHBOOK | Panasonic[]=002001006&p1=&p2=&oc=001005&lang=005
    But I either get "No hard disc's found OR a blue screen of death STOP ..With one sata driver.
    My older CF52 has a a recover DVD XP disc but is not or will not load . It says that no CD drive is supported. or with the Vista DVD is says This model Cf52-2l not supported.
    It has been a few days of trying to get this far.
    It seems like Panasonic has pulled the Sats drive I require .
    Has anyone got an idea ?
    Thanks for reading .
    VT
    OK i found the Sata driver , and it was hidden on Panays web pages :
    http://pc-dl.panasonic.co.jp/dl/docs...1791&trn_org=5
    But now I need to somehow get the Floppy A drive to be recognized while setup disc is in..
    http://www.digital-kaos.co.uk/forums...roblem-124555/
    Read that thread & varmab got me pointed in the correct direction.
    Just had to find the hidden driver.. If Im successful I'll post also .
    I won !!!
    The Sata Driver was hidden
    Under a hyperlink , and then you need read the PDF file to see the controller is one of forty of the download.
    After many hours , and running OS controller type , It shows up ..
    Dang , Im older and less hair but more gray.
    Thanks for the other threads who helped and pointed this dumb-ass in the correct direction.
    VT
    Got that and the CF53 toughbooks all fixed and figured.
    VT
    Mar 2013
    Greetings
    I also have a Panasonic CF-52gcmbxam machine that has Win7 loaded that I purchased on eBay. Since you have the same machine, could you please make a copy of the recovery disc for me? Thanks in advance joecosta66@hotmail.com
    Fec001's Avatar
    I want to buy Pana CF-52 laptop and I need to run xp system on it too. I read posts above and saw there is a solution. I wan to know that is this driver what I need to integrate on Win XP install disc.
    Panasonic Toughbook Computer Support Downloads
    Fec001's Avatar
    link is not ok, sorry
    DOWNLOAD DETAILS:
    Title: [S-ATA HDD driver]
    Notice : This software is S-ATA HDD driver.
    It is necessary at the early stage of Windows Clean Install.
    Model Number: CF-52[G/H][F/T/U](mk2L) Windows XP SP2
    CF-52GFxxxAx (For vPro Model)
    CF-52[G/H][T/U]xxxAx (For Touchscreen Model)
    CF-52[G/H]xxxx2M
    CF-52xxxxxPx? CF-52xxxxx2B (For Windows 7 Downgrade Models)
    Operating System: Windows XP SP2
    Language: English(North America)
    Last Updated Date: 2009/03/06
    Microsoft Signed Yes
