Results 1 to 11 of 11
    Default VW T4 transporter dash fault
    Hi there I have an unusual fault on T4 instrument cluster, the vehicle speed sensor does show correct milage in both engine ecu & instrument pack but displays a 6-10 km difference on display. will this definately be a faulty cluster or is configeration fault in display. also if cluster requires changing is it programmable on a Autocom CDP Pro or do I need a vag .com and how is this done, is immo included inside dash.
    DK Veteran zeljolaki's Avatar
    In my garage
    That the number of your instrument?
    Quote Originally Posted by zeljolaki View Post
    not sure what you mean zeljolak. I summized that the dash panel is faulty and out of sink with true vehicle speed but are these dash panels plug & play, in other words can I just take a similar dash panel from another T4 or even a golf and fit it. or will I need to reprog immobilizer ect ect has anyone got the procedure for changing a dash/ instrument pack, how you keep mileage ect ect
    Junior Member Fenderman's Avatar
    Dec 2011
    Only swap eeproms in dash
    Quote Originally Posted by Fenderman View Post
    Cheers, which eeprom and is this eeprom soldered in or does it need soldering
    Dec 2011
    Depend on year . Could be 93c66 or 93c86 smd.
    Sure is soldered.
    I have autocom cdp pro can I not reprog with this easier, is immobilizer included in dash panel or is immobilizer a seperate component
    Dec 2011
    To swap the dash and reprogramm keys you need both pin codes.
    Its easyer to swap the chips.
    VW T4 doesn't have immo in dashboard!!
    it is in a seperate immobox in the near of the dash,
    you simply can change dash.
    cheers for that I will try to swop dash panels to see if correct mileage is displayed on a different dash panel...
    Top Poster binken's Avatar
    Oct 2010
    sweden
    you can not reprogram the eeprom with autocom cdp
