Results 1 to 8 of 8
    May 2009
    Sydney, Australia
    Default how to read eeprom RH56 2010 prius. immo in transmission ecu
    Hi guys, I am trying to read eeprom rh56 which is in prius transmission ecu for immo. Can anyone tell me what this chip is and if it can be re written.
    cheers
    stefaudio's Avatar
    BULGARIA
    Hi MrMike this is 93c56 but may be rotated pins pay atention
    May 2009
    Sydney, Australia
    Ok I will give it a try and report back. Is there a way to tell if the pin configuration is not normal or just with trial and error? Thanks a lot.
    Mike.
    Look at the PCB pads. The standard chip has GND on pin 5, rotated one is on pin 7.
    marco70's Avatar
    May 2012
    Lawok
    Memory ROHM BR93H56RF-W read and program Seeprog or Wellon VP-990
  6. The Following 4 Users Say Thank You to marco70 For This Useful Post:
    bonecrusher (11th December, 2023), ecufix (15th March, 2020), Mk developments (15th June, 2021), robert1966 (30th March, 2025)
    achaccha's Avatar
    Nov 2010
    I managed to read this report RH56, the problem is to write
    http://www.digital-kaos.co.uk/forums...-write-273757/
    Mr_Fix's Avatar
    Look at the PCB. 6 and 7 pin unused!!!
    Disconnect 6 and 7 pins in programmer panel. Write OK.
    gwee's Avatar
    Dec 2012
    unknown
    Hi Mike, I think i am having the same problem as you.
    Do you happen to have the virgin eprom for the prius transmission controller?
