Nagra, generally speaking it seems the general opinion is that blackberries are the easiest to 'jailbreak', google your phone model and see for yourself![]()
First of all, yes sir it is not a true blackberry. Just the SCH-R351. I love this phone, and have purchased the unlock code. It is locked to virgin mobile canada, and is CDMA. Called up virgin mobile US several times, and said they cannot find the phone. I assume it is because it is not on the sprint network US. Once I unlock, I hope it shows 'sprint'. Only worry I have is if virgin mobile has some sort of database with all IMEI's from USA in it. If it just has to be online, should work, unless you know different about CDMA. Worse come to worse, I would need to reflash the firmware somehow, to run on the sprint network. How do I enter the unlock code on this damn thing? Unlike GSM phones, it has no sim card
hi hope some one can help me unlock my blackberry 8520 curve.
IMEI: 351970047219083
MEP-06814-005
THANKS IN ADVANCE.
The idea is to download the tool and do it yourself!
IMEI : 351970047219083
MEP : MEP-06814-005
MEP Codes:
MEP1 :3292516686831690
MEP2 :4307707153854047
MEP3 :0273569664212581
MEP4 :9575939467109368
MEP5 :8225722186951634
If you get an error, sometimes you need only use first 8 digits of the code.
Is it works on bb 8120 pearl? Thanks
All Blackberry phones provided the MEP is listed!
will it work 4 bb curve 8520?
Have you tried it? That will tell you!
bbdevice manager says the phone is connected but none of the two programs detect the phone, any ideas?
cant get either program to connect to blackberry torch 9810 to list the mep.
most of you will be able to follow instructions from link below to find mep, unfortunatly doesnt work on mine.
>>> http://blog.unlockbase.com/?p=426#<<<<
This applies to both of you...
Check the display on the phone and ensure that it doesn't go into mass memory mode. Select 'Sync Media' and not USB Drive or Charge Only! The description varies between firmware versions, these names are for OS6 but earlier versions should still be quite obvious.
You must have Blackberry drivers loaded, loading Blackberry Desktop Manager to your PC will take care of the drivers!
Check that Blackberry Desktop Manager doesn't automatically start when you plug the USB cable in... This will stop any other programs from accessing the device!
I have just tried the program again under Windows 7 and Windows XP both are working fine! If your using Windows Vista you'll need a full bottle of Gin before you start!
If you still get no joy, start looking at your phones settings and temporarily disable the memory card if necessary via Options. Simply taking the memory card out has no effect, so ensure that you disable via the phones settings!
