Results 1 to 5 of 5
    La Paz, Bolivia
    Default nissan pathfinder 2000 ,TMS inmo
    Hi, I have to program a new key in a 2000 Nissan Pathfinder, remove Immo but I can not identify the model of the processor is a TMS and reading with the UPA or XPROG programmer and generate the transponder with the Tango.
    Can anyone tell me which model of micro TMS?
    Photo attached.
    MEGAUPLOAD - The leading online storage and file delivery service
    thank you very much for your help.
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    Zedbull say this:
    TMS370C040A
    Transponder Type PCF7935
    La Paz, Bolivia
    Thanks for your help.
    I have a question is this module belongs to NATS5?.
    La Paz, Bolivia
    Hello friends, I read the microcontroller with XPROG as TMS370C040A, and wanted to generate the key with tango, but tango does not recognize the file.
    could someone help me read the attached file.
    Thank you for your help.
    Port Elizabeth
    I am speaking under correction but NATS 5 only after 2003 and the system must say step 2 ,4,5 on the label. If it is a diesel then you can bypass immo pm me and I will explain, if Step 2 then it is programmeble with t300 need no pin code just program new key and done . If step 4 then you need to read TMS chip and produce chip from dump it will take a pcf7935, hope it helps
    Cheers
    Shane
